I'm interested in one 68030TK without the CPU and the FPU, is that fine with you, and please delete some of your messages because they are full (Can't PM you)...
Mike..
Mike..
I'm also interested in getting this, but without the CPU and FPU, as I got both of these (planned to do the TF530). Preferably with the A2000 Relocator.
Sorry guy's, had too much work last month, wasn't able to build new TK's.. also got two RAM boards for repair, and this is more time consuming than to build a new board..
Anyway, these two faulty boards are repaired, one is on the way back home now, second one will leave soon..
At this point I'd like to remind one important detail: These boards have powered key pin (Pin20) this is needed to use CF and DOMs without additional power wire. If You like experiments and try to attach CD or hard drives to TK's IDE - PLEASE USE FLAT RIBBONS WITHOUT PIN20 or remove polyfuse. Adding power on that pin for hard drive will break Your drive or/and TK!!!
Meanwhile have built next TK card so this will go further here..
Regards,
-Your 8 Bit Dreams
Not worried Viktor, so Long as I can get one before Christmas...:) (I wonder how long I can holed on to the $$$)..
interested in one 68030TK 50 MHz, FPU, CF adapter, and 4MB for the A1000. With the relocator with two ROM slots.
Hi, if I understand right if I buy the 4MB it can become a 64 just swapping the Ide/ memory card?
If this is correct I declare interest in a ready built and tested 68030 TK (50Mhz), with FPU with 4MB RAM card and CF Card adapter
A2000 version
If there are so many people interested... maybe we could make a big order in some Chines fab company to have that assembled for us? I can try to help with that, if you want.
Interest withdrawn! came cheap to another card Sorry!
Hello Amigans,
wasn't able to build these for a long period because of my daily job (10 hours a day atm)
feel the need to answer some guestions:
You dropped Your interest several times Mike, so You almost last person in queue now, hoping to get Your card before Christmas will not fulfill, unfortunately, really sorry..
that was the plan, and it looked very promising, unfortunately this seems to be non-working atm,
meanwhile have built three revisions of 64MB expansions now - none of them isn't working reliable,
Matze is blaming 96-row connector sitting in between of cards, 100Mhz signal going thru it is too noisy..
SRAM is working without any problems because there are no refresh cycles in SRAM, it works with 50Mhz,
while SDRAM needs a refresh after each cycle, so it runs at double speed
there is no hope to see a working 64MB atm.. Sorry
so everyone should rethink buying this card or not...
You can do it, however i don't want to be involved in this action in any kind
The reason is simple - Matthias statement for this card is "Not for commercial purposes", this is very thin ice,
i don't want to make he angry because this will lead to the all known end - there will be no opensource projects anymore
and this is something what i really don't want to happen..
If You decide to do it - my advice is: ask Matthias before You do something like this, because some of his projects are commercial
(A500/A2000 Grapnic card, 68EC020TK for example) and some not...
it would be funny .. if my eyes would not be much worse since i do these long soldering sessions..
Thanks for reading this, have built a brand new 68030TK, will send payment notification to the next person in queue
thank You for Your patience,
-Viktor
