Dear 68030TK users,
will start an upgrade program to 64MB cards from february
(as spoken previously in this thread)
for the customers who bought 68030TK+4MB version from me
unfortunately this card is still experimental and is not plug'n'play,
this means that several things need to be done
before You will be able to use this card without crashes
Most important thing here is PSU -
it need to be in good shape (recapped)
heavy 2,5A version is too weak and doesn't work for me on any system
Voltage (while system is on) measured on CPU socket should be not less than 4,8V
CPU socket need to be clean and should make good connection to the board
some systems need additional power & GND cables connected to the ram board(Some run without them)
Also Your Amiga need to be recapped in some cases (most caps are dry 30 Years after production date)
Also some boards need 3D Printed cover on the connector that acts like a shield (also piece of foil wrapped in a paper can do the trick)
Unfortunately also TK itself needs some resitor to be changed and
Firmware (Lattice cpld) need also to be updated
this leads to the situation that Your 68030TK card need to be sent to me
(to change 5 resistors to different value and Firmware update)
If You are interested to take a part in this experiment - please let me know!
with best Regards,
-8 Bit Dreams
