Page 35 of 35 FirstFirst ... 253132333435
Results 341 to 349 of 349
Thread: A4000TX ATX Amiga motherboard
  1. #341
    Kavven's Avatar
    Feb 2018
    Sverige
    Medelpad
    9 (100%)
    Removed u455 & u456, reset line is ok again and after adding u212 and u213 i get 512 kB of chipram..
    All 2 mb is soldered though..? :/
  2. #342
    ChewChew's Avatar
    Nov 2019
    United Kingdom
    Beds
    3 (100%)
    Default PS/2 Keyboard Update
    Would it be possible to get the source files for the PS/2 keyboard avr?
    I would like to update the code to bind the PC key scancode 61 aka |\ to rawkey 30 so we can use a custom keymap to faithfully map the GB PC keyboard layout.
    Thanks in anticipation.
    UPDATE
    I've got this working.
  3. #343
    Whoa! This is awesome. It will be even more awesome when the Apollo V4 comes out!
  4. #344
    s800's Avatar
    Sep 2015
    US
    Wisconsin
    2 (100%)
    Two questions:
    - ER975 to ER978, are these 120 Ohm ferrite bead networks or 150 Ohm? In the BOM, they're listed as 150 Ohm, but the Mouser cart has the correct quantity of 120 Ohm (probably not a huge difference, but might as well get it right)
    - I lifted a pad when I flipped the board over and knocked off C404 (argh!). Is C404 the same as C404 on the original A4000? I need to connect the negative pad back up.
    Thank you!
  5. #345
    ChewChew's Avatar
    Nov 2019
    United Kingdom
    Beds
    3 (100%)
    Sorted
    After a bit of research and looking the U206_ATMEGA88.hex file it was quite easy to spot the array mapping the scancodes to raw key codes. Changing the value at offset 7EA from FF to 30 in the .hex file did the trick.
    Quote Originally Posted by ChewChew View Post
    I would like to update the code to bind the PC key scancode 61 aka |/ to rawkey 30 so we can use a custom keymap to faithfully map the GB PC keyboard layout.
  6. #346
    s800's Avatar
    Sep 2015
    US
    Wisconsin
    2 (100%)
    Quote Originally Posted by s800 View Post
    Two questions:
    Answering my own question here, this is a filter cap between the audio section and the rest of the motherboard, so power can be picked up anywhere.
  7. #347
    Sessile's Avatar
    Aug 2021
    West Yorkshire
    1 (100%)
    Well, looks like I might have somewhere ZorroIII to put my incoming ZZ9000 after all! This is a fantastic piece of work Hese.
  8. #348
    Fantastic! I definitely want one. Thanke you, Hese!
    Call me Golan; my parents did.
  9. #349
    s800's Avatar
    Sep 2015
    US
    Wisconsin
    2 (100%)
    I've been up and running on a self-assembled A4000TX for a week or so now. The biggest debugging challenge was a intermittent contact between a pin on a DRAM for chip ram. It looked okay, but eventually I went around and tested each pad -> "leg" and found the bad connection.
    I'll write this off as a problem with using NOS chips. They weren't from China, but had some oxidation that probably contributed to this problem (hypothesis).
    I do still have a problem with the onboard fast ram. So working on that issue.
    Also, beside thanks to Hese, Chuck's DiagRom is absolutely genius.
  1. Wanted Amiga 2000 Motherboard or Repair Service for Motherboard
    By madgrizzle in forum Amiga
    Last Post: 25th June 2017, 12:12
  2. Replies: 3
    Last Post: 5th July 2016, 23:41
  3. Replies: 1
    Last Post: 17th February 2016, 14:50
  4. Replies: 0
    Last Post: 17th April 2015, 12:21
  5. Sold Amiga 1200 Motherboard 'DOA' (just the motherboard)
    By keitha in forum Sales Archive
    Last Post: 12th July 2014, 12:48
