Would it be possible to get the source files for the PS/2 keyboard avr?
I would like to update the code to bind the PC key scancode 61 aka |/ to rawkey 30 so we can use a custom keymap to faithfully map the GB PC keyboard layout.
Thanks in anticipation.
Two questions:
- I lifted a pad when I flipped the board over and knocked off C404 (argh!). Is C404 the same as C404 on the original A4000? I need to connect the negative pad back up.
I have two doubts about the TX. I tried to have the back panel printed using the STL file in the thread by some companies that print in 3D, but I was told that there are thicknesses less than 1 mm. Do you have any advice for me? What material is best to use? Can anyone edit the STL file to increase the thickness to 2mm?
Thank you so much.
My brother is doing a printable variant that I will try out within a week. Its based of the public available (?) stl but with som reinforcements and improvements.
