Surplus to requirements
Memory: 4GB GDDR5
Memory Clock: 7GHz
Memory Bandwidth: 112GB/s
CUDA Cores: 768
Base Clock: 1290MHz
Boost Clock: 1392MHz
Texture Units: 48
ROPs: 32
L2 Cache Size: 1024KB
Transistors: 3.3 billion
Die Size: 132mm2
Process: Samsung 14nm FinFet
Being a dual-slot card, the NVIDIA GeForce GTX 1050 Ti does not require any additional power connector, its power draw is rated at 75 W maximum with a recommended power supply of 500w.
Display outputs include: 1x DVI, 1x HDMI, 1x DisplayPort. The GeForce GTX 1050 Ti is connected to the rest of the system using a PCI-Express 3.0 x16 interface. The card measures 145 mm in length, 111 mm in width, and features a dual-slot cooling solution.
Fully working, comes complete with original installation CD.
80 75 UK pounds with free UK shipping. Worldwide shipping is available on this item.
My other for sale items are: Here
Memory: 4GB GDDR5
Memory Clock: 7GHz
CUDA Cores: 768
Base Clock: 1290MHz
Texture Units: 48
ROPs: 32
Die Size: 132mm2
