Closed Shuttle XPC SN95G5
May be I have one here. You need one with CPU and RAM? May be the Shuttle ST20G5 good enough?
Hi BlindGerMan, thanks for the reply! With cpu and ram would be ideal, but ok without.
im after one which is AGP, and I think the ST20G5 is PCI-E.
I think the S95G5 is one of the last Shuttles with AGP which is why I’d like one of those :)
thanks!
I have this one
its 32bit amd Barton 2500+
AGP , Nforce2 chipset with the better audio solution
https://www.amibay.com/showthread.php?113082-Shuttle-PC-SN41G2
in the below link mine is the only silver one in the picture. 2nd from left
http://www1.shuttle.eu/products/discontinued/barebones/sn41g2/
current config
AMD Barton core 2500+
1gb ram DDR 400 ( 2 * 512mb )
DVD-RW
1.44 FDD
120gb HDD
Radeon X1550 ( AGP )
1 free PCI slot
Has front and back USB 2.0 - Firewire
see web link for full spec.
this is a quiet micro atx setup, was used to hold and serve music.
upgraded to a 250w PSU to cope with addons.
This is the MCP-T version with Nvidia Soundstorm, has digital and optical out + hardware assisted audio.
Geforce 4 MX on board but I use an ATI X1550 as its much faster and has DVI , VGA ,
looking for £80
Thank you for the reply, Sardine, I will have a look at your thread! That’s a nice machine but I think I would rather try and get a s939 machine at first if possible :)
Ok, I found it!
Comes with an Athlon X2 3800+ CPU, 2 GB RAM, a 250 gb harddisk and I thnk a nVidia 4200 Graphics card.
So please PM, if you are interested!
did you get it from BlindGerMan ??
If so feedback needs to be exchanged.
No, if a deal had been done with blindgerman than it would have been documented here.
