Results 1 to 3 of 3
Thread: A600 RGBtoHDMI
  1. #1
    ryanm101's Avatar
    May 2019
    Northern Ireland
    Down
    36
    0
    Default A600 RGBtoHDMI
    I have 3of A600 RGBtoHDMI for sale (these are also advertised on Facebook Amiga group).
    Does NOT include the RPi
    Comes with 2x 2.54mm header (not soldered).
    This will still required soldering to fit to A600 (16 solder points but all fairly simple, it's worth considering removing RF & Composite connectors to provide route out for HDMI)
    Image below shows output to 55" 4K screen @ 1080p
    IMO this adaptor is a must if you are not using a CRT, I've not tested but I also see no reason why it wouldn't work in parallel for with crt as a capture output.
    Prices (includes P&P):
    £25 UK
    £30 Rest of world
    This was a test wireup to verify the display so yes it is a bit messy and its enamelled (magnet) wire not bare copper.
    Last edited by ryanm101; 22nd February 2021 at 17:00. Reason: Update to mention advertised elsewhere. - Added note about P&P
  2. #2
    Lead Moderator
    Administrator
    Sardine's Avatar
    Mar 2012
    England
    Merseyside
    238 (100%)
    so is this now ECS compatible as those modes where not supported ??
  3. #3
    ryanm101's Avatar
    May 2019
    Northern Ireland
    Down
    36
    0
    The current version of the board also supports a SuperDenise but only as long as one of the OCS screen modes is used (320x256, 320x512 interlaced, 640x256, 640x512 interlaced).
    So I'm afraid not, I honestly don't know if they will ever be supported.
  1. For Sale RGBtoHDMI adapter for A500/500+
    By highpuff in forum Amiga
    Last Post: Yesterday, 14:37
  2. For Sale RGBToHDMI V2, For A500,A500+,A2000,CDTV
    By ozkano in forum Amiga
    Last Post: 20th February 2021, 23:59
  3. Replies: 9
    Last Post: 21st October 2020, 15:57
  4. Replies: 3
    Last Post: 22nd May 2019, 19:23
  5. Swapped Commodore Amiga A600, A600 spare case, 2 disk drives and 2 games
    By ricardosaraiva in forum Amiga
    Last Post: 6th January 2015, 12:49
