Found Sam440ep, Sam440ep-flex
sailorMH
Czech Republic
Central Bohemia
Hello, do somebody have old AmigaNG - Sam440 computer?
I am interested in:
- Sam440ep, 667MHz version motherboard
- Sam440ep-flex, 733MHz or 800MHz version motherboards
I am also interested in accessories like RAM, backplate, or original AmigaOS4.1(fe) and SW.
Others accessories like PCI cards, HDD/SSDs, case, etc. can be discussed.
Regards
Hello,
I have a SAM440ep rev.C with a 512MB Memory module installed for sale, if you are still interested.
// Thomas
Hi Thomas,
thank you for message. I am interested if it is 666 MHz version. Please look.
( there was also 533 and 600 MHz versions )
best regards
Sailor
Hello,
on Sam440ep-flex there was a sticker from ACube with frequency. Look if it is also on Sam440ep.
If there is not, we can look on top of CPU - code looks like: PPC440EP-3J667CZ. The bold numbers should be 667.
We can also turn on the Sam and look on Uboot ( but I think that there are not frequency info) and than to AmigaOS.
Or if you have some invoice or documentation from purchase.
Hi, there is no sticker on the board which tells the frequency. I will take the CPU cooler off and send you the info afterwards.
...ohhh I just saw that the CPU cooler is glued to the CPU so I better shouldn't pull it off. Is there a program like "whichamiga" on classic's which will show the frequency?
// Thomas
a little correction - CPU part nr is: PPC440EP-3JC667CZ ... i forgot there first "C" letter, but frequency code should be the same.
Got it :) Found PPCCPUinfo on aminet :cool:
and it's a 666Mhz CPU as you can see on the pictures.
Have added additional pictures of the complete system! System includes a 120GB Samsung SSD with installed OS4.1 final
