Results 1 to 7 of 7
Thread: Gvp a500-hd+ External RAM/HDD
  1. #1
    lilwashu's Avatar
    Mar 2020
    Hants
    9 (100%)
    Default Gvp a500-hd+ External RAM/HDD
    GVP A500-HD+ with 52MB hard drive and 2MB fast RAM. In good condition, slightly yellowed as pics. Tested in my Rev 5 A500 - RAM works fine and have completed several test cycles in ATK. Hard drive worked for a bit but now doesn't at all, although it spins up OK and sounds fine - you have to disable it via the switch on the top for the machine to boot. This could be my A500 or it could be something wrong with the drive/SCSI circuitry on the board.
    This one has been set up to be powered from the A500 so your PSU will need to be in good working order (or remove the jumpers and power it externally) - no PSU is included.
    Was 150 > now 80 plus shipping.
ID:	165042Click image for larger version.
ID:	165043Click image for larger version.
  2. #2
    lilwashu's Avatar
    Mar 2020
    Hants
    9 (100%)
    NOTE I have updated this listing after further testing.
  3. #3
    Dietikon82's Avatar
    Apr 2018
    Switzerland
    6005 Luzern
    39
    1 (100%)
    It may sound silly, but have you sprayed the contacts of the 50pin cable and other connectors? I've had plenty of trouble in my old PCs until I did that every so often.
  4. #4
    lilwashu's Avatar
    Mar 2020
    Hants
    9 (100%)
    I've tried contact cleaner in all connectors to no avail. I did do a bit more testing on it however:
    -It boots from floppy using BindDrivers (Kickstart 1.2) every time and recognises and then boots from the HD, but will lock up randomly while doing intensive operations
    -If I disable the onboard RAM on the GVP, it locks up straight away
    I think my A500 doesn't like it, but can't be sure.
  5. #5
    MadHox's Avatar
    Aug 2020
    Swiss
    Valais
    1 (100%)
    Interested. Pm incoming.
  6. #6
    PRS's Avatar
    Dec 2015
    Dutchieland (Netherlands)
    Utrecht
    69 (100%)
    I have also the same expansion (not currently connected). I’m experiencing exactly the same issues, but that is due to a failing (original) HDD. It functions properly with a SCSI2SD board.
    Amiga 500 Rev.3 (stock) + CDTV (2MB chip, 8MB fast, SCSI, kickstartswitch)
    Amiga 500 Plus (2MB chip, A314 RPi, GVP A530, GVP AT286, 8MB, 4-way kickstart switch)
    Amiga 1200d Rev. 1d4 (BPPC 66/333Mhz, BVision, HxC floppy, PicoPSU, RapidRoad)
    Amiga 4000d (CyberstormPPC 68060@50Mhz, Picasso IV, RapidRoad)
  7. #7
    lilwashu's Avatar
    Mar 2020
    Hants
    9 (100%)
    Payment received from MadHox, tracking information sent.
  1. Replies: 4
    Last Post: 23rd September 2017, 06:07
  2. Replies: 31
    Last Post: 24th February 2016, 15:14
  3. Closed A500 External HDD and Ram module
    By amigo-mexicano in forum Found Archive
    Last Post: 26th March 2008, 06:50
