Page 1 of 4 1234 LastLast
Results 1 to 10 of 34
Thread: Amiga VGA Adapter BUFFERED + VERTICAL LINES REMOVER! Made with original DB23F + internal PCB!O_o
  1. #1
    axel81's Avatar
    Jan 2020
    Italia
    Monza Brianza
    48 (100%)
    Default Amiga VGA Adapter BUFFERED + VERTICAL LINES REMOVER! Made with original DB23F + internal PCB!O_o
    ...The best Amiga RGB-VGA adapter on the WEB..
    What's new?
    --> VLR system (vertical line remover)
    and remember that is made with original D-SUB DB23 female
    History...and future
    I have read and received inquiries in this time since I successfully put the VGA adapter made with the original DB23 connector on sale. To date almost 800 units have been sold between forums and other online channels. Great success and appreciation for having an original DB23F connector on board (not a cut DB25)
    Many of you were bored by those annoying vertical lines that arise with the use of LED matrix (example Benq BL702A). This LCD monitor is one of the few monitors that allows you to almost completely obviate these "vertical bars" by adjusting the various parameters of meł such as the "pixel clock".
    But not all LCD monitors / TVs (compatible with 15KHz) have this feature, so the result is images with these annoying vertical stripes which are really bad.
    From today this will finally be just a distant memory.
    With the new VGA ADAPTER with VLR system (vertical line remover) you can use any monitor / TV (compatible 15KHz) without having to change the image parameters (pixel clock, etc.)
    Furthermore, the saturation / color of the RGB components is improved with the new adapter (you can see it in the second photo)
    Graphic comparison:
    STANDARD VGA ADPTER (on BENQ BL702A)
ID:	166593 Click image for larger version.
    ADAPTER VGA with VLR (on BENQ BL702A)
ID:	166594 Click image for larger version.
    This is the ONLY VIDEO ADAPTER realized on PCB board (buffered) + vertical line remover (VLR) made with ORIGINAL DB23 Female : no DB25 cutted!
    >>> ...take your time and check all the pictures...check the real and original DB23 PIN <<<
    ADAPTER FEATURES
    1) D-SUB DB23-pin female (ORIGINAL COMMODORE) to DB15-pin HD female.
    2) All connection realized with high quality PCB
    3) Backshell cover adapter is DB25-DB15
    4) Buffered version VLR (vertical line remover)
    COMPATIBILITY
    This adapter allows you to connect a VGA/SVGA* or Multiscan monitor to your Amiga RGB port.
    This is fully buffered for Commodore-Amiga 500, 500+, 600, 1200 or "big box" Amiga systems (also for A4000, just ask me in order to cut little bit the cover shell)
    This adapter allows you to use the following display modes:
    • DBLPal
    • DBLNTSC
    • Euro 36Hz and 72Hz
    • Super72
    • Multiscan/Productivity
    • VGA Only
    IMPORTANT NOTE:
    *SVGA monitor must be able to sync the Amiga's 15Khz signal (most CRT monitors have no problem doing this). Some LCD monitors such as DELL U2410 or BENQ BL702A sync down and support 15Khz- check your monitor specifications for more information.
    If your monitor does not support 15KHz, then you will not get a picture until the software drivers are installed and workbench is loaded.
    PRICE
    SHIPPING INCLUDED (EUROPE)
    25€
    PRICE SHIPPING INCLUDED (AMERICA ZONE/CANADA/ECC)
    26€
    PRICE SHIPPING INCLUDED (AUSTRALIA/OCEANIA ZONE)
    27€
    With Paypal traditional +6% on total amount for fees
ID:	166247Click image for larger version.
ID:	166248Click image for larger version.
  2. #2
    na103's Avatar
    Jan 2019
    Italy
    Reggio Emilia
    23 (100%)
    Thumbs up
    1pz. shipping in Italy.
    p.m. incoming with some question
    -- update --
    p.m. with shipping address sent
    -- update --
    payment sent
    -- update --
    adapter received, works great ! feedback left
    tested on my Amiga 2000 OCS with monitor Benq BL702A
    some pictures:
    black screen on boot with adapter bougt on amigastore.eu , you can see vertical stripes
    same foto with this adapter
    in this picture can you see vertical stripe and distorsion with amigastore.eu adapter
    adapter inside
    VIC20(2x)/C64(7X)/C16/PLUS-4/C128/C128D/PC20
    A500(3x)/A500+/A600(2x)/A1200/A2000(3x)/A3000D/CDTV
  3. #3
    Lead Moderator
    Administrator
    Sardine's Avatar
    Mar 2012
    England
    Merseyside
    243 (100%)
    please explain why this thread was created when you have the below thread ( last posted Today 13 minutes before this thread )
    thanks
    https://www.amibay.com/showthread.ph...PCB-INSIDE!O_o
    old price €15 this thread €25
  4. #4
    axel81's Avatar
    Jan 2020
    Italia
    Monza Brianza
    48 (100%)
    Quote Originally Posted by Sardine View Post
    thanks
    Dear Sardine
    this is new listing because
    https://www.amibay.com/showthread.php?113911-Amiga-Video-Adapter-RGB-to-VGA-SVGA-(BUFFERED)-with-DB23-ORIGINAL-PCB-INSIDE!O_o --> Adapter unbuffered or buffered version
    https://www.amibay.com/showthread.ph...ternal-PCB!O_o --> Adapter buffered + vertical line remover
    It's not the same product...that's new type of VGA adapter
  5. #5
    Lead Moderator
    Administrator
    Sardine's Avatar
    Mar 2012
    England
    Merseyside
    243 (100%)
    I asked because the Photos 1, 6 and 8 in the other thread are IDENTICAL and used in this thread suggesting the exact same product.
    so the above photos in this thread are not of the actual item for sale with Adapter buffered + vertical line remover ?
  6. #6
    Steffest's Avatar
    Jun 2017
    Belgium
    Antwerp
    20 (100%)
    Interested in one just for the promise of "vertical line remover".
    I must say I'm sceptical, but hey: only 1 way to find out, right?
    Will send DM for shipping and payment details.
  7. #7
    axel81's Avatar
    Jan 2020
    Italia
    Monza Brianza
    48 (100%)
    Quote Originally Posted by Steffest View Post
    PM sent
  8. #8
    Lead Moderator
    Administrator
    Sardine's Avatar
    Mar 2012
    England
    Merseyside
    243 (100%)
    I would appreciate an answer
    thanks
  9. #9
    axel81's Avatar
    Jan 2020
    Italia
    Monza Brianza
    48 (100%)
    Quote Originally Posted by na103 View Post
    -- update --
    -- update --
    payment sent
    -- update --
    some pictures:
    adapter inside
    Well done ..thank you again
    thanks
    Dear Sardine
    being that I am waiting to integrate what can be seen in the photo sent by "na103" I have not yet inserted a final photo as it is a preliminary that has all the functional characteristics in order to guarantee what is reported in the description: vertical stripes removal and improvement video distortion.
    I will soon have an integrated printout (like the one in the photo) available.
    But the functionality will be the same.
    I also understand that many "impatient" do not want to wait any longer ... for this reason the PCB + bunk PCB version is available
    In any case I'll upload new image asap
    Regards
  10. #10
    Lead Moderator
    Administrator
    Sardine's Avatar
    Mar 2012
    England
    Merseyside
    243 (100%)
    ok that's fine.
    we don't allow stock photos only photos of the actual product for sale.
    thanks and seems from na103 works as described.
  1. Replies: 82
    Last Post: 5th May 2021, 21:32
  2. Replies: 0
    Last Post: 11th December 2020, 19:24
  3. Sold Custom made internal gotek drive for Amiga 600
    By Schuimpy in forum Amiga
    Last Post: 10th January 2017, 20:06
  4. Wanted Buffered IDE 4x Adapter for Amiga 1200
    By locnar77 in forum Amiga
    Last Post: 29th December 2013, 02:07
