Results 1 to 3 of 3
Thread: A4000T Rom socket position?
  1. #1
    Woz's Avatar
    Nov 2016
    Carmarthenshire
    Age
    52
    14 (100%)
    Default A4000T Rom socket position?
    Hi all, just to clarify as I'm going to solder on the Rom sockets on my A4000T motherboards. I have an original Amiga Technologies boards that almost completed and one of the great reproduction models off tbtorro. Looking through pictures etc of the original Amiga Technologies boards the sockets are located to the Left but reading through tbtorro's advice/tips he says to locket the sockets to the Right? Could someone clarify which is the correct position for these?
Name:	A4000T Rev 4 HR Pic Motherboard.jpg
  2. #2
    StanMoonie's Avatar
    May 2020
    United States
    NorthEast
    0
    Reread his advise because where to solder the sockets for the rom counts on what type of rom chip you are using. Tbtorro use to have a small site up that showed the process of him putting together one of these board, with a lot of pictures which was great, it is no longer up for some reason. If you are using the 27c400 eprom they go to the right, if the KS Rom they go left. Now it has something to do with the pin outs on the chip.
  3. #3
    Woz's Avatar
    Nov 2016
    Carmarthenshire
    Age
    52
    14 (100%)
    Hi, thanks for your help, I going to use an official, KS 3.1.4 chip? So would I solder the sockets to the left? Would DiagRom work if I position them to the left as well?
  1. Sold 4-position ATEN KVM switch CS-64A
    By salaxi54 in forum Other
    Last Post: 18th June 2019, 11:27
  2. Replies: 7
    Last Post: 15th April 2018, 19:02
  3. X-Copy TNG Screen Position
    By Storm in forum AmiOracle
    Last Post: 1st December 2012, 02:02
  4. Closed 24 Position Edge Connector
    By BinoX in forum Found Archive
    Last Post: 8th July 2012, 16:24
Tags for this Thread
