Well guys my new 500 + board is just about finished (Waiting on just 4 chips). I don't see a problem booting up since I have fitted a full working Amiga chip set (I moved them from a working 500 v6 board) I even built the 1 MB chip ram board (EDO Dram), and the trapdoor ram board too. I sure do like the chip ram board, as it only has 2 chips, and I had the ram PCB boards made to match the same color as the main-board (Purple).
I will also have the CF LED board made too. It plugs into the keyboard header and a wire go's from the LED board to pin 39 on the CF adapter board. That way the floppy drive LED in act as the hard-drive LED (Board will be Purple too).. For the CPU, I'll be using the PISTORM.. Oh the keyboard plugs into the LED board, and that's how it work's..
