axel81
ANNOUNCEMENTS
The best Amiga VGA - VGA adapter upgrade available on the WEB. From toaday new VLR Upgrade available based on adapter DB23F to DB23M (all connectors are genuine)
This version needs one modification inside the original RGB-VGA adapter: simple wire in order to connect pin23 of your DB23 (+5V) to pin9 of your HD DB15
Please note that my new VGA Adapter buffered V2.0 is already modified with this wire..in case of future upgrade with this part
From today T15HD VLR UPGRADE (HD DB15 male IN / HD DB15 female OUT) is available to transform any BUFFERIZED ADAPTER (not just made by me "AXEL81L") into a VGA ADAPTER BUFFERED with VLR system ... removal of vertical bands!
A solution for anyone who already has an RGB-VGA solution even not purchased in my STORE but who wants to enjoy all the advantages of a video viewing and enhancement on their AMIGA
Note: It is also possible to supply it with customized VGA connectors (male IN - male OUT). Always specify when purchasing!
VLR UPGRADE DB23 PLUS (NO modification is needed)
New entry from today
This version was developed following a simple request from everyone "but if I can't modify my adapter / cable, can't I use it?". Well now this adapter is available that solves this problem by being mounted upstream of everything.
Then it connects to the Amiga RGB port and on it you can connect your Adapter or cable that you have used up to now. So you won't need to change anything: simply add this adapter which is made up of two original DB23 connectors (male and female) as you can see in the picture.
What's new?
--> VLR system (vertical line remover) that fix vertical line on your LCD monitor/TV 15KHz horizontal compatible
--> VDE system (video distortion enhancement) that improve video quality and NO background noise
History...and future :smile:
I have read and received inquiries in this time since I successfully put the VGA adapter with VLR system made with the original DB23 connector on sale.
To date more than 325 units have been sold between retrogamer forum and other online channels. Great success and appreciation for this VLR SOLUTION
From today this will finally be just a distant memory. From today dreams come true thanks to this new VGA to VGA adapter
So you can simply use any of your VGA ADAPTER (DB23 / DB25cut to VGA) with my new VGA-VGA adapter that integrates VLR
Many of you were bored by those annoying vertical lines that arise with the use of LED matrix (example Benq BL702A). This LCD monitor is one of the few monitors that allows you to almost completely obviate these "vertical bars" by adjusting the various parameters of meù such as the "pixel clock". But not all LCD monitors / TVs (compatible with 15KHz) have this feature, so the result is images with these annoying vertical stripes which are really bad.
With the new VGA ADAPTER with VLR+VDE system you can use any monitor / TV (compatible 15KHz) without having to change the image parameters (pixel clock, etc.)
Furthermore, the saturation / color /distortion of the RGB components is improved with the new adapter (you can see it in the second photo VDE system )
Graphic comparison:
STANDARD VGA ADPTER (on BENQ BL702A)
ADAPTER VGA with VLR (on BENQ BL702A)
This is the ONLY VIDEO ADAPTER realized on PCB board (buffered) + vertical line remover (VLR)
ADAPTER FEATURES (Upgrade T15HD)
1) VGA to VGA adapter DB15HD
2) Backshell cover adapter is DB9 - DB9
3) Realized on PCB
4) VLR (vertical line remover) + VDE (video distortion enhancement) on board
ADAPTER FEATURES (Upgrade DB23 PLUS)
1) DB23F to DB23M adapter
2) Backshell cover adapter is black
COMPATIBILITY
This adapter allows you to connect a VGA/SVGA* or Multiscan monitor to your Amiga RGB port.
This is fully buffered for Commodore-Amiga 500, 500+, 600, 1200 or "big box" Amiga systems (also for A4000, just ask me in order to cut little bit the cover shell)
This adapter allows you to use the following display modes:
IMPORTANT NOTE:
*SVGA monitor must be able to sync the Amiga's 15Khz signal (most CRT monitors have no problem doing this). Some LCD monitors such as DELL U2410 or BENQ BL702A sync down and support 15Khz- check your monitor specifications for more information.
If your monitor does not support 15KHz, then you will not get a picture until the software drivers are installed and workbench is loaded.
PRICE
VLR Upgrade T15HD --> 23€ + shipping
VLR Upgrade DB23 PLUS --> 32€ + shipping
VLR UPGRADE T15HD (modification is required)
VLR UPGRADE DB23 PLUS (NO modification is needed! Ready to use it)
PLEASE NOTE
1) Added a screw on the side for fixing to the Amiga. This way we have at least one anchor point.
2) For A4000 the cover will be slightly filed as per the last photo.
The first buyers of the Forum have already received it with these changes and are satisfied with it
- VLR Upgrade T15HD --> based on DB15 HD to DB15 HD (modification is required)
- VLR Upgrade DB23 PLUS --> based on DB23F to DB23M (NO modification is needed!)
What's new?
Graphic comparison:
3) Realized on PCB
COMPATIBILITY
- DBLPal
- DBLNTSC
- Euro 36Hz and 72Hz
- Super72
- Multiscan/Productivity
- VGA Only
IMPORTANT NOTE:
PRICE
PLEASE NOTE
