Results 1 to 2 of 2
Thread: DIY: Cheap 23 pin Amiga Video cable connector
  1. #1
    Wears pants, sometimes... Inactive Member
    Amibayer!
    thgill's Avatar
    Nov 2008
    Cincinnati, OH
    Age
    45
    28 (97%)
    Default DIY: Cheap 23 pin Amiga Video cable connector
    Although this is pretty common knowledge, I thought it was worth repeating.
    You can easily trim down a db 25 pin female connector to fit in the male 23 pin socket on the back of the Amiga. For the same price as a single 23 pin connector, you can buy and mod a whole handful of 25 pin connector. Plus the 25 pin connector housings (hood) is much cheaper as well.
    Just use a little saw, or do as I did and use a Dremel moto rotary tool and and equip it with a cutoff disc. Takes all of about 10 seconds to trim away at the plastic and metal to remove 2 pins from the connector. Couple mm of material. Now it fits right into the 23 pin video socket!
    Couple pics:
    Instant 23 pin connector!
  2. #2
    Inactive Member RetroHacker's Avatar
    Mar 2011
    New York
    0
    Hehe. That looks very familiar...
    If you use the all plastic type of connector (without the metal surround), you can whittle it down with an Xacto knife.
    Not that I have ever done that before, oh no...
    -Ian
  1. Replies: 5
    Last Post: 9th February 2011, 10:28
  2. Found Amiga 500 RGB Scart monitor (video) cable
    By ckong in forum Amiga
    Last Post: 29th January 2011, 22:27
  3. Closed A1200 mouse cable with connector.
    By bebek in forum Found Archive
    Last Post: 29th December 2010, 21:51
  4. Closed Apple proprietary DA-15 video to DE-15 VGA connector
    By Muzer in forum Found Archive
    Last Post: 25th September 2010, 18:35
  5. Sold Sold- Amiga RGB Video -> RGB Scart cable
    By AndyC in forum Sales Archive
    Last Post: 30th July 2009, 00:14
Tags for this Thread
