Page 1 of 7 12345 ... LastLast
Results 1 to 10 of 63
Thread: A1200 accelerator cards: A buyer's guide
  1. #1
    Acceleration! Treasurer
    Amibayer!
    Site Developer
    Administrator
    AndyLandy's Avatar
    Aug 2009
    Southampton
    Age
    39
    107 (100%)
    Thumbs up A1200 accelerator cards: A buyer's guide
    So, this has come up a few times recently, so here's a lowdown on what you can plug into the trapdoor on your A1200. Hopefully this is useful to people, particularly our newer members who are just getting (back) into the exciting world of Amiga hardware!
    FastRAM cards
    These are the most basic expansion you can pop into an A1200 trapdoor slot. The simplest ones tend to be plain 4MB cards (There might even be a couple of 1MB or 2MB cards out there, but I've never seen one). The top of the range ones have a full 8MB FastRAM, real-time clock and support for an asynchronous FPU up to 40MHz. Some cards even use the A500 'Ranger' address space to give you 9MB FastRAM. Some models may take RAM in ZIP or SIMM form, others will have it soldered directly on the card.
    For a basic A1200 WHDLoad setup, a FastRAM card is a nice addition, it will double the speed of your A1200 and give some RAM, enabling you to WHDLoad the vast majority of games.
    The A1200's on-board CPU is the Motorola 68EC020 at 14MHz. EC models of the '020 support 32-bit access of the RAM, which is why they're that bit faster than 68000-based Amigas, but they only support 24-bit addressing, hence the 8MB FastRAM limitation. Be aware that putting in an 8MB card is likely to cause conflicts with your PCMCIA port. Indeed, some cards will allow you to jumper them to 4MB so as to not interfere with the PCMCIA. You could do a lot worse than add a switch allowing you to choose between 4MB and 8MB depending on what you're doing that session.
    Budget accelerators
    The next step up from just some FastRAM is a basic accelerator. There are a couple of 28MHz 68020 cards out there that'll give you a nice speed boost over the stock 14MHz CPU, but with the same 8MB/4MB+PCMCIA limitation as the RAM-only cards above. There are also a few 68030-based cards out there which have the same RAM limitations, such as the M-Tec 1230. It's worth noting that clock-for-clock, an '030 is only marginally faster than an '020. Again, many of these models have FPU support and real-time clock circuits.
    Mainstream 68030 accelerators
    The 68030 CPU has a full 32-bit address bus, so can theoretically address up to 4GB(!) of RAM. Many 68030 accelerators take advantage of this to allow you to get round the A1200's 8MB limit. At the most basic end, you're usually looking at a 33MHz '030 with up to 32MB FastRAM. These cards invariably take standard PC 72-pin SIMMs, so you'll see them offered with different amounts of RAM. (Watch out for GVP accelerators though, they tend to require proprietary 64pin GVP SIMMs which aren't as commonplace).
    The new ACA1230 models essentially fall into this category, too. None of these cards will conflict with your PCMCIA port as they put all their RAM into the 32-bit address space, leaving the PCMCIA port untouched.
    At the top end of the spectrum, you've got the king of the 68030s: The Blizzard 1230 IV with its 50MHz CPU and FPU, supporting 128MB FastRAM on the card and an optional SCSI module that itself can take yet another 128MB FastRAM.
    High-end 68040 and 68060 cards
    If you really want to push the boat out, you can eschew the modest 68030 in favour of the much faster 68040 and 68060 CPUs. At this level, there isn't quite the range of different cards, but the big players (Apollo and Blizzard) both have offerings in this market. The card designs for '040 and '060 are often very similar and if your '040 card has the right logic (MACH131 chips rather than MACH130 ones) it is quite likely that it can be upgraded to an '060 with the addition of a new CPU, a 3.3V voltage regulator and appropriate timing oscillator. Again, these cards will all support at least 32MB FastRAM and once more, some models have optional SCSI kits available. Be aware that once you get to this level you will probably need to consider a higher-rated power supply and give some thought to air-flow and cooling. This is particularly pertinent with early revisions of '040 and '060 CPUs as they can be pretty power hungry and will generate quite a bit of heat.
    PowerPC
    If you want to go the whole hog, the BlizzardPPC is the only real offering out there. Supporting AmigaOS 4.0 as well as some enhanced features in 3.9, a PowerPC can give you some pretty serious performance, but it usually comes with an equally serious price tag! These all come with a 'companion' CPU, either a 68040 or 68060 to remain compatible with the classic Amiga environment, as well as a PPC 603e, running at 160MHz-240MHz for accelerated PowerPC code. Our resident PPC guru, stachu100 has pushed these cards to their limits, getting 68060 CPUs up to 80MHz and PowerPC ones to 330MHz! The points above about higher-rated PSUs and decent cooling/airflow are even more pertinent here when you're running two CPUs.
    FPU, MMU, RTC, WTF?
    FPU = Floating Point Unit, these are occasionally useful for some productivity apps, but the majority of Amiga software doesn't need one. Full-core '040 and '060 CPUs have one built-in, LC040/060 ones don't. '020 and '030s can take either a 68881 or 68882 module, either synchronous or asynchronous to the CPU clock. Nine times in ten, you probably don't care.
    MMU = Memory Management Unit. These allow for paged virtual memory access. To the first approximation, nothing needs one. EC030 CPUs are missing it, but full-core 030s have it. If you're doing some serious coding and need a decent debugger, or you want to play with 68k Linux, you'll need an MMU, otherwise, don't worry about it. I believe WHDLoad can take advantage of an MMU if one is present, but it'll work quite happily without.
    RTC = Real-time clock. Just in case you need your Amiga to remember what time it is between reboots. It's nice to have, but hardly a big deal. If you're doing a lot of hard-disk based work, having timestamps on your files might be useful. If you're gaming, you probably don't care. Beware, some earlier A1200 cards have Ni-Cad 'barrel' batteries to keep the time. These are prone to leaking and should be removed ASAP! You can replace them with a newer Ni-MH 'barrel' or do the lithium coin-battery hack. (More on this another time)
    Pricing
    OK, so this is Amibay and we don't discuss prices outside of an actual transaction, but it's fairly safe to say that cards generally get more expensive as you descend the list. A1200 cards tend to change hands often enough that they have reached a price equilibrium and determining the 'going rate' for any given model isn't too difficult.
    Caveat Emptor!
    Before laying down your hard-earned on any A1200 card, it's always worth checking out BBOAH or Amiga Resource. Both sites have very comprehensive information on just about every card that's out there. Some cards are picky with which RAM modules they support, some have a SCSI option, others don't. Some take weird proprietary GVP SIMMs. Some won't fit in a standard desktop A1200, being designed for use in a tower conversion. Make sure you know what you're buying before you buy it, and save yourself a lot of headache later.
    Happy hunting!
    Last edited by AndyLandy; 5th February 2013 at 15:08. Reason: Tweaked wording on power, air-flow and cooling of 040/060 CPUs
    Thinking about accelerating your A1200? Check out my buyer's guide.
    Projects past and present: Amiga 2000/030 | Amiga 3000/040 | Amiga 4000/060
  2. #2
    Inactive Member
    johnim's Avatar
    May 2010
    birmingham
    Age
    45
    153 (100%)
    great little guide there mate perfect for as you said newbies and old hats getting back into the amiga. This needs stickying.
    Gone but not forgotten. RIP John.
  3. #3
    we live as we dream. Alone. VIP
    Amibayer!
    mjnurney's Avatar
    Aug 2010
    england
    Milton Keynes
    Age
    49
    182 (100%)
    should be a sticky me thinks...
    great guide Andy
  4. #4
    Incoming ASROC! VIP
    Amibayer!
    salaxi54's Avatar
    Apr 2009
    GREECE
    Athens
    134 (100%)
    @Andy: Great shopping guide you made there mate, but ehhmm you forgot to analyze the WTF? terminology
    Joking aside, well done!
  5. #5
    The 1 That Ribbits Inactive Member
    Amibayer!
    cosmicfrog's Avatar
    Aug 2008
    Leek, Staffordshire Moorlands
    Age
    53
    80 (99%)
    Blog Entries
    1
    Gets the ribbits from me
    The one that Ribbits Frist Ribbits Loudest :rainbow::boing::inlove:
    If it dos`t work Hit it with a Hammer, If that dost work get a bigger Hammer, If that dos`t work get the gas axe out :mad:
    Up Front and Central Takeing flack as usual so the rest of you can do that pincer movement
  6. #6
    R Tape loading error, 0:1 Inactive Member
    Amibayer!
    ptp170's Avatar
    Aug 2010
    Devon
    18 (100%)
    This be useful for a lot of people. Cheers Andy
    ---------- Post added at 17:27 ---------- Previous post was at 17:12 ----------
    EDIT: If this is going to be a sticky (and it should be, but possibly under AmiOracle?!) could we add to this as we go along? For instance there maybe a few common "Noob-got-caught-out" scenarios that might be applicable under each section. I know you've mentioned referencing BBOAH / Amiga Resource but there maybe some merit in having 'issues' listed even if it is common knowledge to most who hover in Amiga circles.
    For example:
    Apollo 1260's require an uprated PSU and/or and additional +5V feed to the floppy power connector.
    DKB1240 Mongoose will only work on an 1200 with 3.0 ROMs. It will work on 3.1 ROM's but the card requires a firmware update.
    etc etc
    I'm sure there are plenty other useful pieces of information that people can chip in with and it would be awesome to have it all in one area so Mr/Mrs Average can sum up all the pro's and cons all in one go!
    4 x 48K ZX Spectrums | 3 x ZX81's | 3 x A500+ | 2 x A500 v1.3 | Acorn A3010 | Amstrad ALT-286 16MHz 170Mb HD | Twinhead 486SX 25 MHz 4Mb Laptop (Dos6.22 Win3.11) | Raspberry Poo running OpenELEC XBMC | Arduinos running water harvester and hot tub
  7. #7
    NOT Miss Er Inactive Member
    Amibayer!
    Misser's Avatar
    May 2011
    The Netherlands
    Rotterdam
    Age
    51
    14 (100%)
    Nice one AndyPandyPanda huggable like guru
    Ever thought about maybe writing a novel or some C= bibble?
    Attached a little bonus, C= at the great wall Beijing 2008-05
    If I don't sell I'll trade for a postcard.
  8. #8
    Inactive Member
    Amibayer!
    ad-rs1600i's Avatar
    Sep 2010
    Britain
    Northamptonshire
    4 (100%)
    Thats a really top guide - thanks for taking the time to write it
    I cannot wait for the day I can build my Amiga up with all the goodies I have been stock pileing....
  9. #9
    Amibayer!
    Site Developer
    Administrator
    AndyLandy's Avatar
    Aug 2009
    Southampton
    Age
    39
    107 (100%)
    Thanks to you all for your kind words. I'm glad this guide appears useful to y'all!
    Quote Originally Posted by ptp170 View Post
    Yes, definite +1 from me. I almost mentioned the DKB 1240/Cobra/Mongoose firmware issue, since I got caught up with that when I had one. There's certainly room for improvement and caveats and other weird foibles that people have discovered could all be injected into the first post in appropriate places.
  10. #10
    Ya' Like it Retr0? Inactive Member
    Zetr0's Avatar
    Nov 2007
    Age
    46
    137 (100%)
    Quote Originally Posted by ad-rs1600i View Post
    Thats a really top guide - thanks for taking the time to write it ...
    And rightly so this is now a Sticky and moved to the Oracle section =)
    8)Flux Mastah' Zee8)
    50 L337 1'M W1R3FR4M3
  1. Replies: 10
    Last Post: 7th June 2011, 10:43
  2. Sold 2 GVP A2000 Accelerator Cards
    By Nathanieltolbert in forum Sales Archive
    Last Post: 23rd June 2010, 23:47
Tags for this Thread
