Page 1 of 2 12 LastLast
Results 1 to 10 of 14
Thread: Someone to make me a cable up
  1. #1
    Amibayer! ratfink's Avatar
    Mar 2011
    Yorkshire
    103 (100%)
    Default Someone to make me a cable up
    I wonder, is there anyone here who could make the cable up for me that is described here, say 2m long should be ok:
    http://www.amibay.com/showthread.php?t=17956
    willing to pay of course .
  2. #2
    Inactive Member Oge's Avatar
    Apr 2011
    Italy
    Mediterraneo
    35 (95%)
    I'm afraid that you need a circuit because signals are different..
    Cheers,
    Oge
  3. #3
    Inactive Member
    Amibayer!
    robinsonb5's Avatar
    Jul 2011
    48 (100%)
    Quote Originally Posted by Oge View Post
    Hmmmm, I'm not so sure. The other thread has a pretty good photo of the card, and there are a couple of opto-isolators in the top-right, right by the DB9, which suggests the signals are MIDI-ready.
    @Ratfink:
    * Is the DB9 male or female?
    * Do you want the cable to terminate in male DIN-5s (to plug directly into MIDI gear) or female DIN-5s MIDI sockets, so you can use standard MIDI cables between the breakout cable and the MIDI gear?
    * Do you need dual MIDI in / out, or just one of each? (Edit: I see that the second MIDI in/out is disabled in the most common mode of usage, so I presume you're after a single in / out, yes?)
  4. #4
    Mar 2011
    Yorkshire
    103 (100%)
    Thanks for the replies.
    Quote Originally Posted by robinsonb5 View Post
    I'll have to dig this card out, I haven't looked at it in a while. Good idea about female din sockets, that would also mean the breakout cable could be quite short. Not sure about the dual in/out question, I'll have to check on this.
  5. #5
    Mar 2011
    Yorkshire
    103 (100%)
    Ok, the DB9 on the card is female [ie. a socket, not pins].
    Regarding the DINs I reckon I will probably only be using one in/out pair in practice as I've only got one external MIDI device at the moment. On the other hand...
    ... if I'm getting a cable made then I'm tempted to get dual in/outs just to cover all eventualities. Unless of course it adds too much to the cost/complexity of the job .
  6. #6
    Inactive Member
    Amibayer!
    robinsonb5's Avatar
    Jul 2011
    48 (100%)
    Quote Originally Posted by ratfink View Post
    Well the little information about this card that's out there seems to be conflicting - according to this thread http://vogons.zetafleet.com/viewtopi...b8980b21b1ca77
    (Which I presume you've seen since that's the same pic that appeared in your previous thread) the MQX-32M can do dual MIDI in both directions, yet the more plausible of the pinouts you found only shows one in! Is your card definitely the 32M?
    Anyhow, if we can figure out excactly *what* needs making I can make it up for you.
  7. #7
    Mar 2011
    Yorkshire
    103 (100%)
    Yep that's where I got my picture. My card looks almost the same and has the following printed on it [same as pictured one]:
    MQX-32M Rev.B
    The two big chips U11 and U2 [top right and bottom left] on mine have stickers on that read:
    Copr 1988 1990
    Music Quest
    MQX32M U11 024
    and
    Copr 1988 1990
    Music Quest
    MQX32M U2 021
    The 1990 date suggests - but I suppose does not prove - that it's the later one. Where Malik's picture has a sticker, mine has printed on the card:
    (c) 1990
    MUSIC QUEST, INC.
    FCC ID: IH9MQ32
    I've since found this link which appears to add the use of pins 2 and 7:
    http://tech.groups.yahoo.com/group/l.../message/26703
    as follows:
    Pin Function
    1 MIDI in 1 positive (DIN connector pin 4)
    2 MIDI in 2 positive (DIN connector pin 4)
    3 GROUND
    4 MIDI out 2 positive current (DIN pin 4)
    5 MIDI out 1 positive current (DIN pin 4)
    6 MIDI in 1 negative current (DIN pin 5)
    7 MIDI in 2 negative current (DIN pin 5)
    8 MIDI out 2 negative current (DIN pin 5)
    9 MIDI out 1 negative current (DIN pin 5)
    If we assume on the basis of the dates that my card is the later revision that Davros's quote referred to, then I guess this fuller pinout should be what's needed.
    It doesn't help with the cabling I think but that paragraph looks like it could be from here:
    http://midiweb.zwarts.ws/info/librar...-outputs.shtml
    That's great, much appreciated . Is the above enough to go on?
  8. #8
    Inactive Member
    Amibayer!
    robinsonb5's Avatar
    Jul 2011
    48 (100%)
    [QUOTE=ratfink;251200]
    Nice find! And yup, the pinout of the second MIDI in was fairly predictable - whoever chose the pinout had an eye for aesthetics!
    It is indeed
  9. #9
    Mar 2011
    Yorkshire
    103 (100%)
    Here's the pictures of the area near the db9, as discussed by pm.
  10. #10
    Mar 2011
    Yorkshire
    103 (100%)
    Payment sent .
  1. want to make custom 44 pin ide cable
    By markb in forum AmiOracle
    Last Post: 20th May 2010, 20:55
  2. what make is this card
    By jailer in forum AmiOracle
    Last Post: 15th January 2009, 22:12
Tags for this Thread
