Page 1 of 2 12 LastLast
Results 1 to 10 of 20
Thread: ide68k (v402) help...
  1. #1
    britlord's Avatar
    May 2013
    usa
    Michigan
    45 (98%)
    Default ide68k (v402) help...
    I just received my ide68k (v402) for my A1000. Though does anyone know where the int2 and ovr is on the mainboard (version 6), as I sure don't know..
    a pic would be GREATLY appreciated..
    OH, is it on the expansion buss pin 9, 10 counting from the front to the back???
    Thanks..
    Mike..
    ---------- Post added at 22:22 ---------- Previous post was at 22:22 ----------
    Anyone??
  2. #2
    piacc64's Avatar
    Mar 2011
    Italy
    Piacenza
    148 (100%)
    pin 16 of paula or 15, need verify
    pin 19 of bus expansion, alias pin 10 side pin unpair
    or pin 21 of 8520 near cpu
  3. #3
    britlord's Avatar
    May 2013
    usa
    Michigan
    45 (98%)
    Oh I thought that the 500 bus expansion was the same as the a1000 but 180 deg so I thought that the traces were the same, and soldered the 2 wires to track 9,10..
    Like this (500 pic) but A1000 from the right side, cos if you turn the 500 board all the way around pin 1 will be at the bottom of the pic eh??..
    Mike..
  4. #4
    britlord's Avatar
    May 2013
    usa
    Michigan
    45 (98%)
    I've found out the bus expansion pin readout (It's 18 and 19), so that Amiga 500 pic must be wrong..
    http://old.pinouts.ru/Slots/amiga_zorro_i_pinout.shtml
    When the hell will I receive my DJ Base Rom adapter, as I can't go any futher till I get it..
  5. #5
    britlord's Avatar
    May 2013
    usa
    Michigan
    45 (98%)
    Hey guys . Can some one please tell me if the A1000 version 6 bus expansion is a Zorro-I or Zorro-II cos on Zorro-II 2 pin 17 is the ovr
    (Zorro-I is pin 1
    Arrr...
  6. #6
    piacc64's Avatar
    Mar 2011
    Italy
    Piacenza
    148 (100%)
    the connector have pin even on top 1,3,5,7,9,11,13,15,17,19,.......
    and odd in the under side like 2,4,6,8,10,...............
  7. #7
    Inactive Member CUF85's Avatar
    Dec 2011
    Canada
    St-Hubert, Quebec
    7 (100%)
    I installed mine using this tutorial on my A1000. Pin 1 is the one closest to you. The picture shown above is not wrong. Use pin 9 and 10. Works great using kickstart 2.05 the one that supports ide or kickstart 3.1.
    http://www.students.tut.fi/~leinone3/ide/i68k.html
    Hope that helps
  8. #8
    britlord's Avatar
    May 2013
    usa
    Michigan
    45 (98%)
    Quote Originally Posted by CUF85 View Post
    Hope that helps
    Ok But how come on Amiga Expansion Bus A.K.A Zorro I pinout pin 9 is NC and pin 10 is +12v
    Mike..
  9. #9
    Dec 2011
    Canada
    St-Hubert, Quebec
    7 (100%)
    I will take a picture later and show you how it's installed on my A1000 ok?
    Edit:
    Not my cleanest work but works like a charm. /ovr to 9th pin and /int2 to 10th pin, not sure about the real pin numbers though.
    I use Twinkick to kick the A1000 with Kickstart 3.1
    I forgot to mention that i had to use kipper2k A1000 cpu adapter (not shown here) or the floppy drive will get in the way of the ide connector.
  10. #10
    britlord's Avatar
    May 2013
    usa
    Michigan
    45 (98%)
    Edit:
    Sure a pic would be nice. But how come that you soldered the wires to the gold track!!! also your ide connector looks like a older version to mine, And do you have a pic of your rom adapter fitted too (If you don't mind me asking)
    Mike
  1. Sold ide68k v402
    By zyga64 in forum Sales Archive
    Last Post: 5th December 2012, 07:14
  2. Closed A500+ With 1mb Upgrade & IDE68k/2gb CF-IDE
    By fitzsteve in forum Sales Archive
    Last Post: 21st May 2012, 19:43
  3. Sold 4mb Fast RAM + IDE68k
    By portarinos in forum Sales Archive
    Last Post: 1st April 2012, 08:06
  4. IDE68k - How to install?
    By fitzsteve in forum AmiOracle
    Last Post: 5th March 2012, 00:36
Tags for this Thread
