I got it somewhat....
Hi Heather,
Thanks for your help but I'm still having trouble with it. Most likely the monitor is the issue. I have a Samsung 22" widescreen that is optimized for 1680 x 1050 and I can't find a resolution other than 640x490 16bit to work with it, everything else throws a not optimized resolution. I have not removed the R307 resister yet. Also at 640x480 I get very bad mouse artifacts left on the screen. I had an older flat panel monitor that supported 1280x1024 but it would not power on when connected to the Picasso.
Any thoughts?
Thanks,
Ray
---------- Post added at 12:44 ---------- Previous post was at 11:54 ----------
Hi Heather,
Well, looks like 640x480 16bit is the only resolution that this monitor likes but it works good. Seems 24bit causes the artifacts. I'll look around for another monitor that plays a little better. I'll also de-solder that resistor R307 see if that changes anything.
Let you know.
Ray
