I've noticed while playing with the Everdrive for the Gamegear that some of the games seems to have a vertical ghosting effect. Is that normal on the Gamegear, or does anyone know what could be causing it?
It's recently had all the caps (that were leaking) professionally changed by a member on the forum as the screen was only viewable at extreme angles so it's unlikely to be anything to do with those.
I've taken some pictures as an example,
Addams family has the lines going up from the gates to the top of the screen, and the health bar seems to be ghosted to the bottom of the screen, then in Frogger the lines run from the top of the top of the box to the top of the screen but the horizontal lines are fine. Are the 2 controlled by separate chips?
