CSA Derringer 030 D3 utility
JanciB
Slovakia
Bratislava
the D3 utility that comes with the Derringer accelerator adds memory to the system. Each time it checks the memory too.
Could somebody skilled modify the utility so it does not check the memory?
I can provide the executable.
Thanx
J.
I already started the thread on EAB when I had the Deringer, but nobody got into it.
Its really annoying that the utility checks the memory which takes quite a long time. Only help is to use simms of less size, which takes shorter to check..
