Results 1 to 2 of 2
Thread: MIDIMAN MM-401 breakout cable
  1. #1
    Inactive Member AlexDroog's Avatar
    Apr 2014
    United States
    Massachusettes
    0
    Default MIDIMAN MM-401 breakout cable
    I just bought a MIDIMAN MM-401 off ebay. It didn't come with the white 9 pin male serial breakout cable. I have looked everywhere for this cable to no avail.
    Here is a picture.
    Thank You
  2. #2
    Amibayer! Lennart's Avatar
    Apr 2010
    The Netherlands
    Zuid-Holland
    21 (100%)
    I don't own this card nor the cable, but it should be possible to make your own cable if you can't find an original one. Judging from pictures of the MM-401 it seems to me that all the necessary components are already on the ISA card, so the cable itself doesn't contain any chips.
    Have a look at the official MIDI electrical specification here and then use a multimeter to determine the pinout of the connector. You should be able to find that out by examining the traces that go from the connector to the Sharp PC900 optocoupler and the various 220 Ohm resistors on the card.
    Hope that helps!
  1. Closed Roland SC-55 & MT-32 & Midiman MM-401 MPU-401 (USA)
    By PeterNC in forum Sales Archive
    Last Post: 9th February 2014, 20:09
  2. Replies: 8
    Last Post: 29th August 2013, 10:09
  3. Closed SCSI Backplate/breakout
    By imnogeek in forum Sales Archive
    Last Post: 5th January 2011, 16:40
  4. Closed Pinnacle DV500 Plus boxed with breakout box
    By bobpard in forum Sales Archive
    Last Post: 18th October 2010, 10:24
  5. Closed Jaguar Pro Controller and Breakout 2000
    By Splurge in forum Found Archive
    Last Post: 14th September 2010, 16:55
Tags for this Thread
