Exilent
Load of mixed IC's part 3 - UNTESTED!
All without postage, ask me.
Don't forget to check my part 1 list! https://www.amibay.com/showthread.php?t=51658
Don't forget to check my part 2 list! https://www.amibay.com/showthread.php?t=59443
Aiwa 82-132-640 - 42 pin dip - function unknown - rare - 7,50 euro
AKAI 8818PU D7520BCW-105 LCX0PE3 - 64 pin dip - 4-BIT SINGLE-CHIP MICROCOMPUTER - 7,50 euro
AMD AM9517A-4PC - 40 pin dip - Multimode DMA Controller - 5 euro
AMD 8535EPP (1982) (HP marking 1820-3514) (Intel P8088-2 8 MHz) - CPU - 40-pin plastic DIP - 8 euro
AMI 7808PW c2552 Song 1 Korea - 40 pin dip - Philips tv - 2 euro
AMI 7738SS 15437 02478 - 40 pin dip - function unknown - 2 euro
AMI 7749HY 1241 0551 C2266 Korea - White Ceramic Grey trace Gold pin - 40 pin dip - unknown function - 7,50 euro
AMI 7823BF 1239 5406 C2420 Korea - White Ceramic Grey trace Gold pin - 40 pin dip - unknown function - 7,50 euro
Ami 8513MA I (131405-00) - 40 pin dip - unknown function - 2,50 euro
AMI 8348E J (CO14889-01) - 40 pin dip - GTIA PAL (Graphics Television Interface Adapter) used in Atari 400, 800, XL, XE, 5200 - 8 euro - sold to rgrocha
Chips P82C202 (scx62065pm/n5) - 48 pin dip - PC/AT COMPATIBLE CHIPSet - 10 euro
ELECTRONIC ARRAYS EA2006 02241 A7531 - 40 pin chip - function unknown - 5 euro
EXAR - XR-2401CP 980 D11014n - 40 pin dip - MODEM Circuit - V.22 bis,V.22,212A Compat,300 BPS min. - 5 euro
Fujitsu MBL8088-1 (intel '78) - 40pin dip (plastic) - Family Fujitsu 8088 - CPU 10 MHz - 5 euro
GTE G65SC02P-3 - (Family GTE 650x) - 40-pin plastic DIP - 3 MHz cpu - 6,50 euro - 3 left
Hitachi HD6801S0P - 40 pin dip - Microcontroller Family Hitachi 680x - 1 MHz - 5 euro
Hitachi HD63A21P - 40 pin dip - 1.5MHz CMOS peripheral interface adapter (PIA) - 10 euro - 2 left
HP 1TM1-0001 85411 SGP - 48 pin dip - ELMER CMOS H - (PERKIN ELMER Model 1100) - 8 euro
Intersil Corporation - ICM7212AMIPL - DIP40 - TIMERS COUNTERS AND 4-Digit LCD DISPLAY DRIVERS - 3 euro
Intersil cdp1806ace - 40 pin dip - CMOS 8-Bit Microprocessor with On-Chip RAM and Counter/Timer - 5 euro
Intel P8048H- 40 pin dip - Family MCS-48 - Microcontroller - 1.79 MHz - philips Videopac G7000 + G7400, MAGNAVOX ODYSSEY 2
Matsushita AN3231K - DIP48 - Luminance Signal Recording/Playback IC for VCR - 5 euro
MITSUBISHI M5L8042-xxxx - 40 pin dip - Family: MCS-48 (8042) 4-BIT PARALLEL BIDIRECTIONAL BUS DRIVERS - 4 euro - 2 left
MITSUBISHI m5l8039p-8 - 40 pin dip - MCU - Family: MCS-48 (8039) - 5 euro
MITSUBISHI M50740-602sp - 52 pin dip - Microcontroller - JVC HR-D120 PROC. VCR's - 8 euro
MITSUBISHI M5L8049-177P-6 (1984/84)-40 pin dip - 8Bit Microcontroller-Microcomputer - Plus interval timer/event counter - 5 euro
MOS 301869 -01 - 40 pin dip - 3183 (8050/8250?) - 6,50 euro
Motorola ZC89324P 1JA7 LLQM9128 - 40 pin dip - 5 euro
National Semiconductor B8013 - 40 pin dip - unknown function - 2,50 euro
National Semiconductor B8046 - 40 pin dip - unknown function - 2,50 euro
National Semiconductor DP8390CN 48-Pin PDIP Drive controller / LAN Node Controller - 8,50 euro
NATIONAL SEMICONDUCTOR B8134 2892805-01 - 40 pin dip - function unknown - 2 euro
National Semiconductor MM5387AA dip 40 Digital Alarm Clocks - 5 euro - 2 left
NATIONAL SEMICONDUCTOR +B8520 (1820-3883) - 40 pin dip - unkown function - 2,50 euro
National Semiconductor - INS8049-6FYG/N - 40 pin dip - Microprocessor - 5 euro
National Semiconductor - SW20464K - 40 pin dip - unknown function - 5 euro
NCR 6500/1 11653-001 - 40 pin dip - CPU - 6500 family - Rare - 10 euro
NEC D223C - 40 pin dip - 4 bit microcontroller - Used in Calculator Sharp CS-1151 and CS2251 - 5 euro
NEC D1206C - DIP42 (1988) - rare - 10 euro
NEC D8237AC-5 - 40 pin dip - HIGH-PERFORMANCE PROGRAMMABLE 4-channel DMA CONTROLLER 5 MHz - 3,50 euro - 8 left
NEC D780C DIP40 2.5 MHz Zilog Z80 (Mattel Aquarius,Canon(V-8,V-10,V-20) msx1 , V-25 +V-30 MSX2, Sega/Yeno SC 3000/3000H
Sega SG-1000, Sega SG-1000 Mark II, Sega Master System, LAMBDA 8300, Sinclair ZX80/ZX81, Sinclair ZX Spectrum, Timex Sinclair1000, Bandai Super Vision 8000, NEC PC-8000/PC-6001/PC-6601/PC-8801, Casio PV-1000) - 5 euro
NEC D8085AC - 40 pin dip - cpu - Family NEC 8085 - 3 MHz (1978) - 5 euro
NEC D8155C 40-PIN DIP - Static Ram 256 Word 8-Bit with I/O Ports/Timers Single 5V - 5 euro
NEC D8749HC - 40-PIN Dip - High-Speed, 8-Bit, Single-Chip Hmos Microcomputer - 5 euro - 2 left
NEC D8035LC - 40-PIN Dip - 6MHz, 8-bit Microcontroller - 4,50 euro
NEC D70108C-8 - 40-PIN Dip (1984) - CPU - Model 8088, Family NEC V20 - 8 MHz - 5 euro
NEC D8041AHC154 DIP40 - audio processor with BBE sound enhancement and SRS Labs' TruSurround 5.1 channel virtualizer. It includes all of functions processing audio signal for TV, such as volume, balance, mute, tone control, eala NJRC original surround and simulated stereo 2functions. All of internal status and variables are controlled by I C BUS. - 10 euro
NEC D8049C - 40 pin dip - MCS-48 - Timer controler - used in Roland Cr8000, Casiotone 401, Korg Polysix Voice Board, Roland JX-8P - 5 euro, Roland Juno 60 Synthesizer - 2 left
NEC D70108C-8 - cpu 8 MHz Family NEC V20 - 40-pin plastic DIP - 6,50 euro
NEC D7201C - 40-PIN DIP - Protocol Controller - 5 euro
NEC D7507C - 40 pin dip - 4 BIT SINGLE CHIP CMOS MICROCOMPUTERS - 5 euro
NEC V20 D70108D-10 - CPU - 8088 10mhz - 5 euro
NEC D7538C - 42 pin dip - Atari 2600 - 5 euro
NEC D80C42C - 40 pin dip - 8-bit CPU PPI controller 8 mhz - 5 euro
NEC D8049C - 40 pin dip - MCU 8048 family - Philips Videopac G7000/20, Casio MT-40/41, Casio PT-7, Supra Mpp 1150 Parallel Printer Interface, Roland Cr78 Drum machine, Korg Trident MkII
NEC D71055C - 40 pin dip - Parallel Interface Unit - N8VEM SBC-188 v1.0 - 5 euro
Oki M5840H-91 (japan 7802) - 40 pin dip - CMOS 4-BIT SINGLE CHIP MICROCONTROLLER (tv) - 7,50 euro
Olivetti 8808k5 - Italy Gap 1A Japan - unknown function - 8 euro
RCA - CDP1802CE - 40 pin dip - CPU - 2.5 MHz(RCA 1802 family) - 10 euro - 2 left
RCA CDP1806ACE - 40 pin dip - cpu - Microcontroller Family RCA 1802 5 MHz - 7,50 euro
RENESAS (MITSUBISHI) - M5L8042-198P - 8-Bit Microcontroller - 5 euro
ROCKWELL R6765P - dip 40 - (Micro Processor Family = 8080) Floppy Disk Controller - Double Density Floppy Ctr - 5 euro
SGS co14805 -12 - 40 pin dip - GTIA NTSC (Graphics Television Interface Adapter) used in Atari 400, 800, XL, XE, 5200 - 8 euro
SGS NC/4A/AWL/3870 (Mostek 3870 clone) 8-bit microcontroller is a single chip implementation of Fairchild F8 (Mostek 3850) - Use for healthkit aircraft navigation, audio etc.) - 5 euro
Signetics - SCN8049H - 40 pin dip - SINGLE-CHIP 8-BIT MICROCONTROLLER - 5 euro
Signatics 8211 6.32379-01 - 40 pin dip - ceramic - unkown function - 5 euro
Siemens sab8237a-5-p (P8085) - 40 pin dip - DMA Controller - 3,50 euro - 2 left
Siemens SAB 8031A-P (intel 1980) - 40 pin dip - Micro controller - 6 MHz - 5 euro
Sinclair ZX81 ULA Ferranti ULA 2C210E 40 pin dip - Fix Those ZX81 Video Display Problems - 10 euro - sold to emilen72
SMC 8450 16206-003 9004 - 40 pin dip - function unknown - 6 euro
Sony 8-751-941-02 or Cx-194b-2 - Dip 42 (compatible with Sony 8-751-941-00 Cx194b-5) - Betamax videorecorders, tape recorders, sony u-matic) - 10 euro - 2 left
SPI 122097-00 7005-129-01 8420 - 40 pin dip - function unknown - 2 left - 2 euro
SPI 2057400 8331 79 - 40 pin dip - function unknown- 2 euro
Star Micronics - 8927KX (08240013 lc-2) (Mitsubishi - M50734SP ) 8-BIT CMOS MICROCOMPUTER - 6502 enhanced version - 5 euro- Used in LC10 printer
STMicroelectronics - 3265-07590 - NPN General Purpose Amplifier - 2 euro
Synertek SY6845RA - 40 pin dip - CRT CONTROLLER FAMILY (http://www.datasheetarchive.com/dl/Scans-002/Scans-0053400.pdf) - 5 euroSGS EF68821P - dip 40 pin - - unknown function - rare - 10 euro
Synertek P6520A (C014795) (MOS Technology MCS6520) - 40 pin dip - PIA (Peripheral Interface Adaptor used in 8-bit computers) - Atari XL800 - 5 euro
Synertek SYP1793-002 40-PIN DIP 1983 - Controller IC - rare - 10 euro
Texas Instruments TMS9914A - dip40 - (1989) GPIB interface Controller - 5 euro
Texas Instruments SN74LS612N TI 40-Pin MEMORY MAPPER TMS9900 FAMILY - 8 euro - 2 left
Texas Instruments NC TEX 6A TAST B335 J - 40 pin dip - function unknown - 2 euro
Texas Instruments CF60062CN 1820-3957 MA54000 - 40 pin dip - 5 euro
Thomson EF6802P - 40 pin dip - MCU 68xx family - 8 euro - 2 left
Toshiba TMP8048AP - 1721 Z6 - A3 8749HB (intel 1980) - 40 pin dip - 8-Bit Microcontroller - 5 euro
Toshiba TC17G005AP-0010 - 40 pin dip - CMOS GATE ARRAY (VTech Laser 700) - 8 euro
TK-10 5732 8401H Japan - 40 pin dip - unknown function - rare - 7,50 euro
VLSI VC2093/PCU01A DIP 40 pin - unknown function - rare - 10 euro
Vtech GA003 - 40 pin dip - VTech Laser 310, Dick Smith VZ300 computer - 5 euro - sold to emilen72
Vtech GA004 - 40 pin dip - VTech Laser 310, Dick Smith VZ300 computer - 5 euro - sold to emilen72
Vtech GA008 - 40 pin dip - VTech Laser 310, Dick Smith VZ300 computer - 5 euro - sold to emilen72
Xebec 3198-0009 8330FM - 40 pin dip - Xebec S1410 5.25" Winchester Disk Controlle
ZILOG SL0080-00 2892797-01 - CPU - 5 euro - 3 left
ZILOG R724 RT3D7FZ8614 118610-002A 9313 JN - 40 pin dip - 5 euro
