Updated
Updated
Added card installation tip and cleaned up...
Updated
Can you maybe add some definitive info on whether or not you should/can use a Cyberstorm PPC in a A3000D and whether it requires additional work, i.e. fans, modification, etc.?
Awesome post!
I just dug up my 3000T and while I had battery damage from it I was able to easily fix it with jumping wires after carefully cleaning everything. While I remembered there were revision and combo issues in general, it's nice to see all this curated into a single post.
One thing you could add with the A3640 section is that some revisions of the boards requires changing some caps (the metal ones) that were inverted (still works but could lead to electrolyte leakage in the long run).
