For Sale Useful Amiga Cables & Adapters
a.mi.goun
Czech Republic
Prague
I have for sale some useful Amiga Cables and Adapters:
Some of them I sell in other threads, here you can find them better sorted.
Payment: Paypal gift or SEPA Banktransfer. Prices do not include shipping costs.
* All Amiga Video RGB adapters/cables with use precisely modified DSUB25 connectors, if you require original DSUB23 it is for 4€ extra.
* Number of pictures in the post is limited - clicking over a cable/adapter title (or icon near the title) will show larger photo.
ITEMS CONSTANTLY ADDED THRU TIME. RECENTLY ADDED ITEMS ARE MARKED *NEW. ALL CABLES/ADAPTERS LISTED ARE CURRENTLY AVAILABLE for SALE.
avga-metal-small.jpgAmiga Video RGB to VGA Adapter
- Allows connecting Amiga native Video to LCD monitor. If that monitor supports 15 kHz mode (like BenQ BL702A or BL912), you will get a great picture comparable to a scandoubler. More info here. For deluxe adapters and cables and more options check here.
Price:
11 €
argb-vga-cable.jpgAmiga Video RGB to VGA Cable
- Alternative to Amiga Video RGB - VGA Adapter is completly modified SVGA cable for even more comfortable and easiest way of connecting Amiga to any 15kHz compatible monitor. (Please note that for bigbox Amigas such as A4000 and monitors other then BenQ BL702A / BL912 you need buffered sync signal). Buffered sync is for extra 5 €. For deluxe cables and more options check here.
Price:
15 €
Amiga Video RGB to GBS 8200 (8220 or HD-VC9900) Cable
- This cable will connect your Amiga to GBS 8200 Video Converter. Also compatible with GBS 8220 and HD-VC9900. Comes with 680 Ω resistor on CSync as recommended.
Price:
14 €
scart-vga-csync-cable.jpgSCART-VGA (CSync) Adapter
- This adapter can be used to connect Amiga (or other retro computer/console) to GBS-8200 (and similar) video converter assuming you already have SCART cable (wired for CSync) for your computer/console. Optionaly I can add audio output for extra 2€ (in case your computer/console only outputs audio thru scart).
Price:
14 €
Minimig / MiST / MiSTer SCART Cable
- Allows connecting Minimig, MiST and MiSTer to TV with the SCART input.
15 €
Minimig / MiST / MiSTer - Commodore 1084S Cable
- Allows connecting Minimig / MiST or MiSTer to Commodore 1084S (or Philips CM 8833-II) Monitor. I can make the cable with DSUB or DIN connector as needed.
Price:
13 €
Commodore 1084(S) and Philips CM8833-II RGB-Video Cable
- Amiga RGB-Video Cable for Commodore 1084(S) and Philips CM8833-II monitors. Options are: 1/ Commodore 1084S-D1 (or Commodore 2002 or Phillips CM8833-II) monitor with DSUB(Canon) connector (photo). 2/ Commodore 1084S-P1 monitor with DIN connector (photo).
Price:
15 €
scart-amiga.jpgAmiga SCART cable
- Amiga RGB SCART cable. For deluxe SCART cables follow thread here.
15 €
cd32-rgb-scart-cable.jpgAmiga CD32 RGB SCART cable
- RGB SCART cable for Amiga CD32. CD32 must have the 8pin MiniDIN connector, that provides RGB signals. The French CD32 had that connector, others usualy have 4pin MiniDIN (where only SVideo signals are present).
17 €
argb-rattesw-cable.jpgRatte Auto Switch Video Cables
- Cables for Ratte Auto Switch. Options are: 1/ Indivision internal cable to Ratte Switch INPUT1(A) (5 €), 2/ Cable from Amiga external VGA scandoubler to Ratte INPUT1(A) (11 €), 3/ Cable from Amiga external RGB Video to Ratte 10pin port (for use with 15kHz compatible monitor) (12 €) (photo), 4/ Cable from Graphics card VGA output to Ratte INPUT2(B) (11 €)
Price:
11 €
DataSwitch Amiga Solution
- Allows multiple Amigas on one table share one Keyboard, Mouse, Joystick, Audio with the help of a manual DataSwitch. More info here in my other thread.
usb-floppy-rw-adf.jpgADF-Copy Adapter Photo1, Photo2, Photo3
- Nice USB solution for writing and reading Amiga floppy disks from PC by Dominik Tonn based on advanced Arduino compatible controller. Among its unique features is the ADFDrive that allows working with the floppy disk as it was an USB thumbdrive. Also HD floppy disks support and recently added flux-level support for reading disks into SCP format. Nice java-based GUI with lots of useful features. And compatible among various Operatining systems, not only Windows. Price for the adapter is 43 €, optionaly Micro USB cable 1,5€, straight Floppy cable 1 €, USB power cable for floppy drive 6 €.
43 €
Arduino Amiga Floppy Disk Reader/Writer (Drawbridge Plus)
- Another USB solution for writing and reading Amiga floppy disks from PC by Robert Smith. Can read and write ADF files to(from) disk with easy to use Windows application. Newly supports reading to SCP files and also direct floppy disk support with WinUAE emulator. Price for the adatper is 27 €, optionaly Mini USB cable 1,5€, straight Floppy cable 1 €, USB power cable for floppy drive 6 €.
27 €
greaseweazle.jpgGreaseweazle F1 (Bluepill) FDD Reader/Writer
- Great USB interface by keirf for writing and reading (not only) Amiga floppy disks from PC. Working on a flux level, it can read & write SCP, HFE and ADF file formats and also write IPF files. That means it can even duplicate originals. Price for the adapter is 21 €, optionaly Micro USB cable 1,5€, USB power cable for floppy drive 6 €.
21 €
adtwin-cable.jpgADTWin Cable
- Allows writing Amiga disks from PC with Parallel port (for more info check ADTWin website). Optionaly USB power Cable to power the Floppy drive for 6 € or PC floppy drive for 8 €.
Price:
10,5 €
gotekext-silver-cable.jpgCable for connecting GOTEK as external floppy drive
- With this cable you can connect GOTEK floppy as external floppy drive. Gotek is powered directly from external port just like any regular external floppy drive. Cable features genuine 23pin dsub connector. Many cable colors available to choose from in my original thread here.
16 €
bootselector.jpgA500/500+/1000/2000/3000 Bootselector
- Allows booting from the external Gotek (or external floppy drive). Connects to CIA (B) slot. With the switch you can select if internal or external drive is bootable. When external drive is bootable, internal drive becomes invisible. Simply - you can have either DF0 (internal) + DF1 (external) or just DF0 (external). On bigbox Amigas drives just swap being both visible and accessible.
17 €
amigamdpadadapter.jpgAmiga - SEGA MegaDrive Pad Adapter
- Allows safe and correct function of MegaDrive pads on Amiga and C64 (swapped 5V /Select lines + resistor and all signals connected thru diodes). Please note this will not make a full-feature replacement for CD32 joypad, Megadrive pad will only work as a standard joypad with 1-2 button support. Short version of the adapter (photo) fits directly also to Amiga 600 & C64.
11 €
SEGA MasterSystem LightGun/Phaser 3050 - Amiga Adapter
- Allows connecting SEGA MasterSystem LightGun/Phaser 3050 or compatible to Amiga to play supported WHDLoad modified games with it.
11 €
zip100pp-adapter.jpgAmiga - IOMEGA Zip100 Parallel Port Drive Adapter
- Allows connecting parallel port ZIP drive to Amiga (uses Amiga Parallel and Joystick port). New improved version now includes fully shielded cover and passthru joystick connector that can be made to fit A600 as well. For use in big-box Amigas ask me for making longer joystick cable. Special version for Amiga 1000 could be made on request.
16,5 €
sdbox.jpgSDBOX - Parallel Port Micro SD card Reader/Writer
- Allows connecting MicroSD cards to Amiga parallel port for filetransfers. And with a suitable driver boot disk you can make your sdcard work as a portable harrdisk for every amiga (kick 1.3 and higher). For powering SDBox external usb charger is needed or you can power it directly from Amiga with my Floppy port USB power cable.
Version 1 is for 31€ or Version 2 (which supports insert/removal of cards on the fly) is 35€
31 €
Amiga 1000 Standard Parallel port Adapter
- This adapter converts non-standard parallel port built in Amiga 1000 into standard Amiga type parallel port.
12 €
cd32-serial-port.jpgAmiga CD32 Standard Serial Port
- This adapter cable connects to AUX in CD32 and converts it into standard 9-pin serial port (like the Communicator device does). On CD32 only RX, TX signals are present, but it still allows file transfers or playing multiplayer serial games.
13 €
ParNET cable
- Allows connecting 2 Amigas for transfering data and quite fast (files can be accesed thru NET: device in system, just like any other drive/device)
12 €
Serial Nullmodem cable
- Allows connecting 2 Amigas for playing supported multiplayer games or for transfering data. Can come as 3wire or 7wire (for faster transfer rate). Cable can be also made with small COM connector for connecting Amiga to PC. 3wire cable price 9 €, 7wire 11 €.
9 €
Easy 1541 Cable
- Allows connecting Commodore 1541 (and compatible) drive to Amiga to transfer files etc.
10 €
Frodo IEC Cable
- Allows connecting Commodore 1541 (and compatible) drive to Amiga and use it by Frodo C64 Emulator to to transfer files or run the C64 software directly from the drive.
14 €
amiga-usbps2-mouse-adapter.jpgAmiga-PS2 Mouse Cable Adapter
- Allows connecting standard PC PS2 mouse to Amiga. Adapter can come with either PS2 or USB connector (Mouse still has to support PS2 protocol). All adapter types are listed here.
18,5 €
joyswapadapter.jpgA600 mouse/joystick port adapter
- This adapter allows connecting devices to Amiga 600 mouse/joystick that normally would not fit because they use larger connector. Cable version also available.
4,5 €
Joystick UP & Fire Swap adapter
- With this adapter you can swap your joystick's 'UP' direction & 'FIRE' button, so that you can press fire button for jump and the fire is routed to second fire-button (if present). Useful in jumpy games like James Pond 2 Robocod, where most people prefer FIRE button for Jump. Only way is to swap the signal lines and that is what the adapter does. You can decide whether you want swap: UP to Fire1, or UP to Fire2. You can also decide if you want original 'UP' connected or disconnected. Default mapping is UP to Fire1, Fire2 to Fire, original UP disconnected. Connector is compatible with A600 and C64 too.
6 €
db9-extender.jpgAmiga "low-space" mouse/joystick port cable extender & adapter
- This special 9pin Dsub (canon) cable extender allows connecting devices mice/joysticks to Amigas where there is very little space near ports that prevents fitting normal connectors. Also useful in towerized amigas to extend the connectors. Connector will even fit to A600 mouse port, so this cable can be also used as A600 mouse port adapter. You can decide length of the cable.
5 €
Parallel port laplink cable
- This cable allows easy filetransfers between Amiga and PC through direct Parallel port connection. PC Drives are mounted on Amiga as Devices which allows easy file management. You need an old PC otherwise timeouts may occur. Long filenames are supported thanks MSDOS 7 or FreeDOS and DOSLFN. Kickstart 2.0+ is needed to run PC2Am. Software in action is presented here.
10 €
Paradise Amiga-PC Parallel port cable
- This parallel port cable allows fast filetransfers between Amiga and PC through Paradise software. The latest version of the software adds direct usage from Windows.
11 €
cdtvkeyboard-cd32a4000.jpgPS2 Keyboard - Amiga Mini Cable Adapter
- Allows connecting PS2 Keyboards to bigbox Amigas such as A1000/A2000/3000/4000 or CD32 and CDTV. Follow my original thread here for more info.
17,5 €
CDTV Keyboard to CD32 (and A4000) or A2000/3000 Adapter
- This adapter allows connecting CDTV Keyboard to either Amiga CD32 (and A4000) or A2000/3000.
11,5 €
Blizzard vision / Cybervision PPC VGA Cable
- Internal VGA Cable for Blizzardvision (BPPC) or Cybervision (CVPPC) graphics cards. You can decide the length of the cable (default 35cm). When needed I can also provide bracket to mount the VGA connector to for 2 €.
10 €
Indivision ECS or AGA MK1 internal Scandoubler/Flickerfixer cable
- Cable which connects internal Indivision ECS (or Indivision AGA MK1) to Monitor. You can decide the length of the cable.
10 €
Indivision AGA MK2cr (or MK3) internal Scandoubler/Flickerfixer VGA cable
- Cable for Indivision AGA MK2cr with VGA connector. Default length is 30cm. Price is 11,5 € for MK2cr cable and 13 € for MK3 cable.
11,5 €
Indivision AGA MK2cr internal Scandoubler/Flickerfixer HDMI cable
- Cable for Indivision AGA MK2cr with HDMI connector. The HDMI connector can be installed in place of removed RF modulator (you can either screw or glue it in place) or mount on a bracket etc. Cable's HDMI female coupler can be detached to small HDMI plug. Default length 30cm.
Cable2 with small HDMI socket available as well.
23 €
Indivision AGA MK3 internal Scandoubler/Flickerfixer HDMI cable
- Cable for Indivision AGA MK3 with HDMI connector. The HDMI connector can either be installed in place of removed RF modulator (you can either screw or glue it in place) or mounted on a bracket etc. Cable's HDMI female coupler can be detached to small HDMI plug. Default length 30cm.Cable2 with small HDMI socket available as well.
23 €
Indivision AGA MK2cr internal Scandoubler/Flickerfixer DVI cable
- Cable for Indivision AGA MK2cr with DVI connector providing both analog and digital signal just like the original cable. Can be used as a replacement for a broken original cable. Default cable length is 30 cm. Can be made longer or shorter if needed.
Optionaly I can supply with smaller and low profile DVI connector (photo) .
17 €
DCE internal Scandoubler/Flickerfixer cable
- Cable which connects internal DCE Scandoubler/Flickerfixer to Monitor.
10 €
Amiga 4-Player Adapter
- Allows connecting 2 more joysticks to Amiga to parallel port for playing multiplayer games such as Dynablaster and others (list of supported games for example here). Also on PC you can use the adapter with PPjoy driver (for windows XP and older) to use amiga joysticks as digital joysticks. Adapter is wired to support also the second button.
10 €
Amiga Floppy DF0 Terminator
- This adapter removes the delay upon reset when floppy drive is not connected to internal floppy drive port.
3,5 €
Amiga 4000 IDE Terminator
- This adapter removes long delay when you reset Amiga and you do not use any IDE Devices. Useful when booting from other controller such as Fast ATA/SCSI etc.
3,5 €
IDE 2,5->3,5 Adapter
- With this adapter you can connect 3,5" IDE cables into internal A1200/A600 IDE connector. Power cable provides +5V power if needed.
5 €
DIN - PS2 Adapter
- Adapter allows to connect old DIN keyboard to PS2 connector. For example A2000 and A3000 keyboard to A4000.
2,5 €
PS2 - DIN Adapter
- Adapter allows to connect PS2 keyboard to DIN connector. For example A4000 keyboard to A2000 or A3000.
5 €
Internal Floppy power cable
- Used to power internal floppy drives on A500/600/1200 etc. On request I can make other custom power cables, for example cable with three small plugs to power CF adapters also etc.
5,5 €
Amiga M1438 Microvitec RGB monitor - VGA adapter
- Allows connecting Amiga (Microvitec) multisync monitors (that come with 23pin RGB cable) to VGA port (15pin) such as graphics card on Amiga or PC. Features genuine 23pin connector.
14 €
AT-ATX Power Supply Adapter *NEW
- To connect ATX Power supply to motherboard with AT connectors (P8/P9). Works for A4000T as well. Special version of the adapter with integrated -5V power module is for 22€.
20 €
Amiga - ATX Power Supply Adapter
- With this adapter you can connect standard PC ATX Power supply to Amiga 500/500+/600/1200. As there is no supply of original square DIN connector, I use my modified round connector, that work well. Comes with ON-OFF switch.
17 €
Amiga 1200 Micronik Busboard - ATX Power Supply Adapter
- With this adapter you can connect standard PC ATX Power supply to Amiga 1200 equipped with Micronik Bus Expansion Board
18 €
Amiga 2000 - ATX Power Supply Adapter
- With this adapter you can connect standard PC ATX Power supply to Amiga 2000 and thus replace the old, noisy and failing original PSU.
18 €
Amiga 3000 - ATX Power Supply Adapter
- With this adapter you can connect standard PC ATX Power supply to Amiga 3000 and thus replace the old, noisy and failing original PSU.
18 €
Amiga 3000T - ATX Power Supply Adapter
- With this adapter you can connect standard PC ATX Power supply to Amiga 3000T and thus replace the old, noisy and failing original PSU.
21 €
Amiga 4000 - ATX Power Supply Adapter
- With this adapter you can connect standard PC ATX Power supply to Amiga 4000 and thus replace the old, noisy and failing original PSU. Especialy well suited for desktop A4000 thanks to perfect power distribution.
18 €
Amiga 4000 - Direct ATX Power Supply Adapter for modular PSUs
- Direct connect adapter for modular SFX PSUs like Seasonic GX* / Corsair SF* / Evga Supernova GM* and similar range of PSUs. With this adapter you can completly get rid of the cable clutter in A4000. Check my thread here.
21 €
Amiga 4000T - ATX Power Supply Adapter
- use the AT-ATX Power Suppy Adapter listed above
20 €
Amiga CD32 - ATX Power Supply Adapter
- With this adapter you can power your CD32 (or A590 harddrive or Commodore 1541-II floppy drive) from a standard PC ATX power supply.
14 €
Amiga CDTV - ATX Power Supply Adapter
- With this adapter you can power your CDTV from a standard PC ATX power supply.
22 €
Amiga CD32 - Molex Power Supply Adapter
- With this adapter cable you can power your CD32 (or A590 harddrive or Commodore 1541-II floppy drive) with a standard molex connector of the AT/ATX power supply.
9 €
Amiga CD32 - Cisco Power Supply Adapter Cable
- With this adapter cable you can power your CD32 (or A590 harddrive or Commodore 1541-II floppy drive) with CISCO ADP-29EB power supply.
13 €
Floppy Port - USB Power Cable
- This cable can be used to power low-power devices such as SDBox or Plipbox directly from Amiga external Floppy Drive Port. USB connector can be miniUSB or microUSB at your wish. Default length is 20cm. Can come with modified DB25 connector for 11 € or genuine 23pin connector for 13,5 €.
11 €
Amiga-PC Serial Nullmodem Adapter
- With this adapter you can make serial connection between Amiga-PC (and viceversa) for example to transfer data with Amiga explorer or other similar software. Wired for full handshaking (required by Amiga Explorer). If your PC does not have serial (COM) port you can use USB-RS232 Converter (I can supply one for 4 €).
9 €
Amiga 4000 IDE Splitter cable
- This cable enables you use both CF-Card Adapter and CDROM on A4000 internal IDE controller. You may have noticed that when directly connecting CF-Adapter and CDROM to A4000 the CDROM is not recognized. This special cable works similar way as 4xIDE splitters (I integrated the capability directly into the cable), and enables another channel for the CDROM thus making it available. With the help of IDEFix software you can then access the CDROM thru atapi.device on unit 3.
11 €
Paravision SX-1 external HDD cable
- With this cable you can connect standard 40pin IDE device to external HDD connector of the Paravision SX-1 expansion for CD32. As the port provides also +5V, the cable offers posibility to power devices that are ok with just +5V (ideal for CF card adapters).
18 €
68030 or 68040 / 68060 Heatsink (standard or low-profile)
- Hi-quality anodized aluminium heatsink for 68060 or 68040 CPU (Dimesions L:45,7mm, W:45,7mm, H:16,5mm) for 7€ (photo). Also available Low-Profile version (photo) (Dimensions: L:42,5mm, W:45mm, H:6mm) for 4€. Also available heatsink for 68030 CPU (Dimesions L:35mm, W:35mm, H:10mm) for 4€ or low-profile version (height:6mm) for 3,5€ (photo). Heatsinks are highly efficient. I can also include cut-to-size hi-quality adhesive tape for the heatsink for additional 0,5€.
Crystal Oscillator 70 Mhz
- Useful when you want to experiment with overclocking your Blizzard / Cyberstorm Accelerator. Take care of proper processor cooling when operating overclocked.
3 €
Amiga adhesive rubber feet replacement
- Set (4pieces) of hi-quality (3M brand) rubber feet replacement for desktop Amigas 500/600/1200.
1,5€
TF 328 PCB
- Terrible Fire 328 accelerator for CD32 - just PCB -not populated. Bought from S.J Leary years ago. Only one PCB for sale.
12 €
Amiga Test Kit Parallel and Serial Dongles
- Set of Parallel and Serial Dongles for easy testing these Amiga ports with famous Amiga Test Kit program.
18 €
AMIGA MIDI Interface *NEW
- The MIDI interface for serial port provides Amiga with MIDI Out and MIDI In port for connection of the MIDI hardware. Compatible with the popular MT32-Pi project.
Also available MIDI Out interface for Amiga CD32 which connects to AUX port and gives one buffered MIDI out port for 16,50 €.
24 €
Plipbox Nano *NEW
- Great project by Lallafa, Ethernet (LAN) adapter for nearly every Amiga thanks to connection to Parallel port (take into account you need little bit expanded Amiga too- TCP stacks and browsers mostly need some Fast RAM and 68020+ CPUs). For powering Plipbox you need 5V MiniUSB power supply or my Floppy port power cable.
30 €
SCSI Stuff
Blizzard SCSI-Kit IV internal cable (12 €) - Internal SCSI cable for Blizzard SCSI Kit IV. Allows connecting one scsi 50pin device, default length 35cm. Custom length or more connectors on request.
Blizzard SCSI-Kit IV original cable (10 €) - Original SCSI cable for Blizzard SCSI Kit IV with the external DB25 female connector. Can be made with male DB25 connector as well if requested.
Standard 50pin Flat SCSI Cable (5 €) - Default 30 or 50cm and 2 connectors. Custom length and multiple connectors on request. Nice colored cable.
Squirrel SCSI ext-int cable (11 €) - With this cable you can connect internal SCSI devices such HDD's to Squirrel PCMCIA SCSI controller.
For other retro computers I offer:
COMMODORE 8-bit
Commodore Hi-quality Video Cables thread here
Commodore 64 Power Adapter Cable (14 €) (photo1) (photo2)
- This cable adapter allows you to power-on your C64 by two separate power adapters. Just connect 5V AC-DC 1,5Amp and 9V AC-AC 1Amp power adapters and you have a replacement C64 power supply.
Commodore 128 Power Adapter Cable (16 €)
- This cable adapter allows you to power-on your C128 by two separate power adapters. Just connect 5V AC-DC 1,5Amp and 9V AC-AC 1Amp power adapters and you have a replacement C128 power supply.
XE1541 Cable (11 €)
- Allows connecting Commodore 1541 (and compatible) drive to PC with parallel port to transfer files (Star Commander runs from DOS environment). Cable can be also used to simulate 1541 drive from PC by 64HDD software.
1541EMU Cable (15 €)
- This cable and 1541EMU software for PC (DOS) can emulate full Commodore 1541 Floppy drive. With the fact full 1541 is emulated, means fastloaders can work. Depending on the PC parallel port some tweaking may be necessary. How it works I demonstrate here.
Pi1541 Cable opt.A (14 €) (photo) - With this cable you can use your Raspberry 3B or (3B+ 3A+) to emulate Commodore 1541 Floppy drive. Full emulation of the drive makes even fastloaders work.
OTHERS
Apple IIGS - RGB Scart Cable - Connect Apple IIGS to TV or any converter with SCART connector (Hi-Quality OFC cable) - 15 €
Apple IIGS - RGB VGA Adapter - Connect Apple IIGS to 15kHz compatible monitor such as BenQ BL702A or GBS video converter. Wired for CSync - 11 €
ATARI 520ST(M) - ATX Power Adapter - Allows powering ATARI 520ST(M) from standard PC ATX Power supply - 15 €
ATARI ST - Amiga Mouse Adapter - Allows using Amiga mouse with ATARI ST computers - 5 €
ATARI ST RGB SCART Cable - Hi-Quality RGB SCART cable for ATARI ST (depending on your wish it includes the capacitor fix to prevent flickering which may appear on some TV's) - 17 €
GOTEK external Floppy Cable for ATARI ST (works with regular floppy drive as well) in my thread here
PC MIDI Cable - MIDI Cable for PC soundcards with DB15 MIDI/GAME port. Midi In and Midi Out. 2xDIN5M and 2xDB15MF connectors. Optocouplers integrated in the cable - 10 €
MT32-Pi-HAT - MT32 HAT by Chrissy for Raspberry Pi 3/4 prividing MT32 or MIDI emulation - 34 €
Interested in:
(uses Amiga parallel and Joystick port)
PM is on its way ...
Interested in several of the Megadrive to Amiga controller adapters, however need to ask first...
Will these work with ALL Megadrive compatible controllers? The reason I ask is that I have done the simple "swap lines 5 and 7" on many controllers and it does not work on many of the newer 3rd party 6 button Megadrive controllers.
@ Jameson: I have only original SEGA 3 button pad, so I cannot tell, how about 6 button ones. If I have one, I would certainly test. But I would think they should work if they claim to be compatible..
Please put the prices back in the thread.
Must be my phone . Google chrome on android.
I can't see prices. But if I edit your post they show up on the edit screen.
Sorry for the confusion
Also interested in several of the Zip 100 adapters. PM sent.
Payment made for [4] x Amiga/Megadrive joypad adapters and [4] x Zip100 Adapter cables.
Items arrived today. Well packaged and superbly made - very impressed!
Will post feedback shortly.
Thank you.
It should probably be noted that the Zip100 cables will not fit the majority of Amiga systems. It looks like they would fit the Amiga 500 and Amiga 1200, but they DEFINITELY will not fit an Amiga 2000, Amiga 3000 or Amiga 4000.
Unfortunately these are the machines I purchased them for (assuming "for Amiga" ,meant "fits ANY Amiga" not "fits a couple of Amigas" :( )
Anywho, if a.mi.goun could please edit the item description it will at least avoid any other disappointments.
The adapter is here. Thx!! And sry for my late reply - a feedback is on its way .....
