I have for sale a fully boxed as new Gigabyte Brix S (GB-BXi5H) barebones NUC purchased from Aria on the 8/4/2014 so less than 3 weeks old. Its so new that it even has the protective plastic cover on the top of it
This is the new Broadwell i5 unit with the option of both mSata and 2.5" hdd concurrently. Great for speedy OS as well as giving conventional storage options too.
All you need to get this up and running is some low power memory and a hard drive of sorts.
The exact spec of the machine I am selling is:
5th generation Intel® Core™ i5-5200U 2.2GHz / 2.7 GHz
2 x SO-DIMM DDR3L slot (1333/1600/1866 MHz)
Gigabit LAN (Realtek RTL8111G)
IEEE802.11ac, Dual Band & BT 4.0
Intel® HD Graphics 5500
Realtek ALC283 Audio
Mini DisplayPort - Max Resolution 3840 x 2160 @ 60Hz
HDMI - Max Resolution 4096 x 2304 @ 24Hz
1 x mSATA slot
1 x PCIe M.2 NGFF 2230 A-E key slot occupied by the WiFi+BT card
Supports 2.5” thickness 7.0/9.5mm Hard Drives (1 x 6Gbps SATA3)
Front I/O, 2 x USB 3.0, 1 x head phone jack with MIC
Rear I/O : 1 x HDMI, 1 x Mini DisplayPort, 2 x USB 3.0, 1 x RJ45, 1 x DC-In, 1 x Kensington lock slot
VESA: Bracket included Supports 75 x 75 and 100 x 100 mm
Dimensions: 46.8 mm x 107.6 mm x 114.4 mm (1.84" x 4.24" x 4.5")
Cost me just shy of £320 a few weeks ago
Looking for £239 delivered as a barebones machine.
Can supply it with 8GB Ram, a 120GB Samsung EVO 840 mSata and a WD Black 750GB HDD for an additional £100
Advertised elsewhere
1 x mSATA slot
