Results 1 to 2 of 2
Thread: Apple G4 Mirror Drive Door case (for possible case hack) for free
  1. #1
    Inactive Member slaz's Avatar
    May 2010
    London
    Age
    65
    31 (100%)
    Default Apple G4 Mirror Drive Door case (for possible case hack) for free
    As above - pls look up pics of this case - you'll find better pics than I can take right now.
    Back in about 2002 - this was a very futuristic/hip case design.
    I've just (more or less) gutted one - removed mobo and PSU.
    Should be a viable hack for small to mid-sized PC mobos - fitting a ATX PSU should be possible (I think)
    Standard drive bays 2 x 5.25" front bays for optical drives + 2 x internal 3.5" bays. 5 slots for PCI/whatever.
    Its a highly engineered thing .... very cool hinged drop-down mobo plate/side panel ..... Pretty sure I've seen one or two PC mobo hacks for these.
    I need to get rid now - need the space.
    Price ? OK - well 0.01 then Collection only from London E2 - shipping would be silly - its pretty big+heavy.
    I'll leave this here for a few days - after that its the skip - which would be a bit sad :-/
    [edit]
    After having a cursory look into it .....
    A BTX layout mobo would be a much better choice for this. It should be relatively easy to align the expansion slots - in fact this would likely determine the position of the mobo on the "bottom" plate - but there'd be work to do wrt USB, ethernet, audio ports etc.
    Also - fitting a ATX PSU would be easy really - plenty of space above the optical drive cage - will just need the mains input IEC connector of the PSU "extending" to the outside of the case.
    I'll take (on request) detailed internal pics/measurements .....
    So come on you dremel-wielding lot - this would be a pretty cool hack !!
  2. #2
    May 2010
    London
    Age
    65
    31 (100%)
    Well no interest, so case has now gone for re-cycling.
    @MODS - thread can be closed.
  1. Sold Apple G4 Mirror Drive Door parts
    By slaz in forum Sales Archive
    Last Post: 18th January 2018, 11:05
  2. Vic20 Case Hack
    By Hawk in forum Photo Booth
    Last Post: 28th December 2017, 03:43
  3. Closed Apple MDD (Mirror Drive Door) G4 machine - dual G4 @ 1.25GHz
    Last Post: 11th December 2017, 17:03
  4. Wanted disk door for a cd32 case or a complete case
    By hairy12 in forum Amiga
    Last Post: 7th June 2014, 08:10
  5. Closed Trapdoor and SCSI door for A1200 case
    By Mad_Cat_jr in forum Found Archive
    Last Post: 23rd November 2010, 22:39
Tags for this Thread
