Results 1 to 4 of 4
Thread: Rgb/ttl to rgb and the reverse.
  1. #1
    Licence to fish Amibayer! moijk's Avatar
    Nov 2009
    Norway
    Grimstad
    43
    37 (100%)
    Default Rgb/ttl to rgb and the reverse.
    I want to use my C128d with my other rgb stuff and i want to use my cga and ega monitor with my low color stuff that isn't either. Anyone know of anything that does it? I want to retain all colours so ebay China crap doesn't do it.
    Sent fra min F8331 via Tapatalk
    too many toys, too little time...
  2. #2
    "Takai desu ne." -"Jinsei da." VIP
    Amibayer!
    protek's Avatar
    Feb 2008
    Finland
    Oulu, Pohjois-Pohjanmaa
    46
    65 (100%)
    I’ve made a simple ttl to analog converter based on a design that I found. I have a couple of extra interfaxes, if you’re interseted. You’ll just need to make the necessary cables. Not sure about the reverse though.
    http://www.amibay.com/showthread.php...alog-interface
    AMIGA 4000 060/50, AMIGA 1200 030/50, AMIGA 500, C128D, C128, C64C, C64, C16, Vic-20, Atari 520 STE, Atari 65 XE, Philips NMS-8250 MSX2, Sinclair Spectrum +3e, Sinclair Spectrum 48k, Amstrad CPC 6128, Amstrad CPC464, Oric Atmos, Apple Macintosh Classic, Apple IIGS, BBC Master, Memotech MTX500
  3. #3
    MoonDragn's Avatar
    Feb 2021
    USA
    Maryland
    54
    0
    Since the RGBI signal is digital, is there any way to convert it through a raspberry pi to hdmi? If I remember correctly TTL should be 5 volts.. Raspberry data should be around 3.3v So have to use a series resistor and maybe a schottky diode tied to the 3.3v. question is how do you interpret the data coming in and translate it to hdmi? Not familiar with the formats.
  4. #4
    quantum8's Avatar
    Jan 2019
    Australia
    QLD
    11 (100%)
    Do you mean like this project?
    https://github.com/hoglet67/RGBtoHDMI
  1. c64 action replay for reverse engineering
    By roy_bates in forum AmiOracle
    Last Post: 16th February 2016, 17:40
  2. Anyway to reverse Retr0bright damage?
    By abraXXious in forum AmiOracle
    Last Post: 22nd January 2011, 11:04
