Okay I thought I could bypass this problem by installing boing bags 2 and classicwb in winuae and then transferring the cf hard drive to real amiga but no. With default Startup Sequence I still get the red Sofware Failure
I tried something along the lines of your suggestion but I still get:
Software Failure Press left mouse button to continue
Error: 8000 00B Task 540A05D0
with this startup sequence:
Code:
;ClassicWB Startup-Sequence
;OS39
;Start OS3.9 Checks
IF EXISTS C:SquirrelSCSI
C:SquirrelSCSI
EndIF
Set SCSIUpdate 1
IF EXISTS C:IDEFix
C:IDEFix
Set SCSIUpdate 0
EndIF
IF EXISTS SYS:Expansion/XSurfIDE
Set SCSIUpdate 0
EndIF
IF EXISTS SYS:Prefs/Env-Archive/NOSCSIUPDATE
Set SCSIUpdate 0
EndIf
IF $SCSIUpdate EQ 1
C:SetPatch SKIPROMMODULES "scsi.device" QUIET
ELSE
EndIF
Unset SCSIUpdate
;End OS3.9 Checks
C:GetMouseInput LOCAL
IF $MouseInput EQ 1
Unset MouseInput
C:Assign >NIL: ENV: RAM:
C:Assign >NIL: T: RAM:
C:Execute S:Maxmem-Sequence
EndCLI >NIL:
EndIF
IF $MouseInput EQ 2
Unset MouseInput
C:Execute S:Bootmenu-Sequence
EndCLI >NIL:
EndIF
Unset MouseInput
IF EXISTS C:StackAttack
C:StackAttack
EndIF
C:Version >NIL:
FailAt 21
IF EXISTS SYS:WBstartupD
C:Rename >NIL: SYS:WBStartup SYS:WBStartupM
C:Rename >NIL: SYS:WBStartupD SYS:WBStartup
EndIF
Resident >NIL: C:IconX PURE
Resident >NIL: C:WBRun PURE
Resident >NIL: C:Assign PURE
Resident >NIL: C:Execute PURE
Resident >NIL: C:SetEnv PURE REPLACE
IF EXISTS L:env-handler
C:MakeDir RAM:T RAM:Clipboards
L:env-handler
ELSE
C:MakeDir RAM:T RAM:Clipboards RAM:ENV RAM:ENV/Sys
C:Copy >NIL: ENVARC: RAM:ENV ALL NOREQ
Assign >NIL: ENV: RAM:ENV
EndIF
Assign >NIL: T: RAM:T
Assign >NIL: CLIPS: RAM:Clipboards
Assign >NIL: REXX: S:
Assign >NIL: PRINTERS: DEVS:Printers
Assign >NIL: KEYMAPS: DEVS:Keymaps
Assign >NIL: LOCALE: SYS:Locale
Assign >NIL: LIBS: SYS:Classes ADD
Assign >NIL: HELP: LOCALE:Help DEFER
IF EXISTS C:BlazeWCP
C:BlazeWCP
EndIF
IF EXISTS SYS:System/FBlit/FBlit
SYS:System/FBlit/FText
EndIF
BindDrivers
C:Mount >NIL: DEVS:DOSDrivers/~(#?.info)
C:LoadMonDrvs
SetEnv Language "english"
SetEnv Workbench $Workbench
SetEnv Kickstart $Kickstart
UnSet Workbench
UnSet Kickstart
IF EXISTS C:CyberBugFix
C:CyberBugFix
EndIF
IF EXISTS C:IconBeFast
C:IconBeFast 0
EndIF
C:AddDataTypes REFRESH QUIET
IF EXISTS SYS:System/VPrefs/VisualPrefs
Run > NIL: SYS:System/VPrefs/VisualPrefs
EndIF
C:IPrefs
SYS:System/FPalette/FPPrefs
C:ConClip
Path >NIL: RAM: C: SYS:Utilities SYS:Rexxc SYS:System S: SYS:Prefs SYS:WBStartup SYS:Tools SYS:Tools/Commodities
SYS:System/REXXMast >NIL:
IF EXISTS S:User-Startup
Execute S:User-Startup
EndIF
Resident Execute REMOVE
Resident Assign REMOVE
C:StackAttack AUTO
EndIF
C:LoadWB
EndCLI >NIL:
---------- Post added at 19:43 ---------- Previous post was at 19:25 ----------
Okay I think I could just start by booting from safeboot-sequence and work my way up from there.
Classicwb39 boots and gives error:
Cannot open "workbench.library", version 45
Unable to run "Amidock".
OK
There are no actual icons on desktop, but there are small rectangular icon placeholders. Also there is background image and the memory amounts are displayed in top right...
So this is the safeboot sequence renamed into startup sequence.
Where should I start, which lines should I add to get desktop icons and amidock back?
I have yet to try if my external cdrom works, I suppose it may not...
Code:
;ClassicWB Safeboot-Sequence
;OS39
C:StackAttack
EndIF
C:Version >NIL:
FailAt 21
EndIF
L:env-handler
ELSE
EndIF
C:BlazeWCP
EndIF
EndIF
BindDrivers
C:LoadMonDrvs
UnSet Workbench
UnSet Kickstart
C:CyberBugFix
EndIF
C:IconBeFast 0
EndIF
EndIF
C:IPrefs
C:ConClip
;Start of S/User-Startup Replaement
IF EXISTS C:AntiClick
C:AntiClick
EndIF
Execute S:Assign-Startup
Assign >NIL: LAUNCH: SYS:System/BMenu/Files
Assign >NIL: VMEM: SYS:T
Assign >NIL: AWEB_APL: SYS:Internet/AWeb_APL
C:Copy >NIL: S:Ram.info RAM:Disk.info
Run >NIL C:RamSnap
;BEGIN MUI
IF EXISTS SYS:System/MUI
Assign >NIL: MUI: SYS:System/MUI
IF EXISTS MUI:Libs
Assign >NIL: ADD LIBS: MUI:Libs
EndIF
IF EXISTS MUI:Locale
Assign >NIL: ADD LOCALE: MUI:Locale
EndIF
C:Version >NIL: exec.library 39
IF NOT WARN
IF EXISTS MUI:Docs
IF EXISTS HELP:dummy
EndIF
Assign >NIL: ADD HELP: MUI:Docs
EndIF
EndIF
EndIF
;END MUI
C:xfdPatch >NIL:
Run >NIL: C:XpkMasterPrefs
IF EXISTS C:BorderBlank
C:BorderBlank
EndIF
;End of S/User-Startup Replacement
C:StackAttack AUTO
EndIF
C:LoadWB
EndCLI >NIL:
