Sold Commodore Golden TV Scart Cable (S-Video, StereoSID, Chroma Modification V2.0 + Audio Noise Removal)
  • Thread starter Thread starter Oge
  • Replies Replies 82
  • Views Views 15118
Oge
Rating - 95%
37   2   1
Italy
Mediterraneo
Golden TV SCART Cable (PAL/NTSC) that works with any Commodore 64 or Commodore 128.
While this item has similar features compared to the Deluxe TV SCART Cable already listed here on AmiBay, it also features a robust round gold cable (which is pretty appealing and looks great) and a stronger Chroma modification which furtherly improves compatibility with newer LCD televisions. It is longer, too.
Features as follows:
S-VIDEO:
Also known as S-VHS, represent the best video mode when it comes to C64/C128 systems
CHROMA MODIFICATION (V2.0):
Improves compatibility with newer LCD TVs. Compared to the Deluxe TV SCART Cable, the Chroma Modification was made stronger in order to furtherly accomodate the S-Video signal to standards. Of course, the Cable will also work with classic CRT TVs
CHROMAREVO (
ChromaREVO makes possible to display S-Video on TVs which fail to display it even using the Chroma Modification. If you think that you own a troublesome TV (or you are unsure about its capabilities) request ChromaREVO instead of Chroma Modification: its benefits applies to both CRT and LCD TVs and it has been proved to just work everywhere
STEREOSID (DUAL MONO):
The audio output is doubled to both Left (L) and Right (R) channels. This modification is rather simple but pretty important as several TVs will not upmix the mono signal coming out from the SID
AUDIO NOISE REMOVAL (SID ANTI-NOISE):
Thanks to the usage of an appropriate capacitor noises, hisses and hums are erased
STRONG:
DIN Connector internally potted with silicone in order to resist against traction and intense use
HIGH QUALITY:
Soldering done with Audio Grade Solder for optimal conductivity and highest quality of the signals
PICTURE:
PRICE: €14,00
SHIPPING: EU (€6,30); Outside EU (€8,20)
AVAILABILITY: X8
Cheers,
Oge
I'm working on a new revision of the "Chroma Modification" and Myst will be the first one to check it out. :)
Cheers,
Oge
No.. I still have some of these. PM sent to BuckoA51 and tlosm.
Cheers,
Oge
Cable & Video Problems
Just come the cable after a loooooong wait ...
how about ... just check my screenshots ....
this is the result, all white perimeters have a purple lines , and the black have dirty lines on the back ground....
and the monitor make a background noise ...
It looks like the Chroma Modification is not enough for your LCD TV. Dunno if attenuating it even more would help, PMed you in order to know better about this issue.
It seems that your TV handles S-Video but C64 Chrominance is still too strong.
Cheers,
Oge
Cheers,
Oge
I dont know ogre but... I tried the cable on 3 different TV
1)LG Flatron LCD 24'' full hd 1080p (purple and black whit strange effects and noise audio)
2)Sony Bravia LCD 42'' HD 1080i (purple and black with strange effect and noise audio)
3)Panasonic Viera 65'' 3D Full HD 1080p better on this only some purple and green on the top of the screen
I dont know what tv use the other guys but on lcd & plasma ... there are problems with croma colors
Thank you for the having test it on different LCDs, a replacement with a different Golden Cable is on your way.
Cheers,
Oge
I've been using mine with the XRGB Mini, a Sony 40" inch LCD and a Cambridge Audio amp, quality is spectacular, close to RGB with very minimal ghosting on the image (like, stick your nose up to the screen to see it ghosting). There's a tiny, tiny tiny bit of audio noise if I crank the amp right up, but absolutely minimal and way less than my old cable. In fact it was so quiet when I first used it I thought sound was not working :)
Highly recommended!
Highly recommended!
I dont know i have problems on all MY tv probably the cable have problems...
Ps i have tested it on MY marantz amp and bose 5.1 system noise in background only more amplified
