Exilent
PLEASE CLOSE, NO LONGER FOR SALE!
I have for sale some Digi International AccelePort hardware:
1x - Digi AccelePort C/CON 16-port RS-232 RJ-45 Serial Hub - Rev B - 15 euro+pp
1x - Digi AccelePort C/CON 16-port RS-232 RJ-45 Serial Hub - Rev D - 15 euro+pp
2x - Digi AccelePort C/CON 16-port RS-232 RJ-45 Serial Hub - Rev G - 25 euro+pp each
I have only one PSU left, so the first one get it. I will include a picture so you can find the correct PSU. No drivers, but can be found on the net.
Summary of the Digi AccelePort C/CON-16 RJ-45 - concentrator
If you think configuring a large-scale multiuser system is a complex, expensive process - think again. Thanks to the AccelePort C/X asynchronous concentrator, it's not only simple, it's surprisingly affordable. This Digi C/CON Concentrator offers high-speed surge-protected EIA-232 serial ports.
C/CON-16 Concentrator
The Digi C/CON-16 concentrator is a complete subsystem with its own 80C186
microprocessor, 128K of RAM and 16K of EPROM, 16C554 quad UARTs for
the sixteen EIA-232 asynchronous serial ports, and a high-speed 85C30 serial
communications controller with full duplex DMA support for communication
with the host adapter and other concentrators. The concentrator receives packets
of data from the host adapter at data rates of up to 1.2 megabaud, then distributes
the data, as appropriate, to the sixteen EIA-232 ports. Data received by the EIA-
232 ports is similarly packetized and sent to the host adapter over the high-speed
synchronous line. The EIA-232 ports operate at data rates of up to 115,200
baud. Multiple concentrators may be daisy chained together, and with standard
wiring, concentrators may range up to 300 meters (1000 feet) from the host
adapter.
By using high-speed synchronous modems, remote concentrators may be located
virtually anywhere in the world.
Compatibility
Digi AccelePort C/X - serial adapter(7700044)
Features of the Digi AccelePort C/CON-16 RJ-45 - concentrator
adapter.
Compatibility
- Product Description Digi AccelePort C/CON-16 RJ-45 - concentrator
- Device Type Concentrator
- Form Factor Rack-mountable
- Processor 80186
- RAM Installed ( Max ) 128 KB
- Ports Qty 16
- Data Transfer Rate 115.2 Kbps
- Data Link Protocol RS-232
- Power ( 50/60 Hz )
- System Requirements IBM OS/2, SCO OpenServer, UnixWare, IBM AIX, SunSoft Solaris, DEC OpenVMS, HP-UX, SunSoft Solaris x86, Novell NetWare, Linux, Microsoft Windows 2000, Digital UNIX, QNX, UNIX SVR4, Microsoft Windows NT
- Designed For AccelePort C/X
