Hi All,
I've been testing today a method for quickly reproducing Amiga CF cards and have found WinImage really useful for this:
http://www.winimage.com/winimage.htm (Works fine on my Win7 64bit PC)
I created my 4gb CF in WinUAE as per normal, setting up Classic Workbench and fully loading my CF with WHDLoad Games/Demos.
Using WinImage I was able to make a complete image of my CF in less than 20 minutes and restore another CF as an exact replica in about the same amount of time. The actual speed will obviously depend on the specification of your PC.
It is however much faster than recreating in it WinUAE from scratch (this process normally takes me a couple of hours, mostly waiting for WHDLoad Games to copy!)
It's definitely a great way to back up your CF's and restore them should you have any unfortunate accidents
Here are the steps to backup your CF:
Here are the steps to restore your backup file:
I found that even a brand new CF card without any Amiga RDB was able to have the image written to it and works like a charm. No need to use Diskpart to clean it first!
WinImage is a Shareware program and the unregistered version is only usable for 30 days. After that you need to register
Thanks to Johnim for pointing out, you can also use your Virtual Hard Drive image with WinUAE, just mount it like any other HDF and you can boot from it and use your Workbench.
Thanks for reading!
Enjoy
- Download and install WinImage
- Remove your CF card from your Amiga (carefully!)
- Plug the CF into your PC's USB Card reader
- DO NOT let Windoze format the CF
oh: - Open WinImage
- In the menu bar at the top choose 'Disk/Create Virtual hard Disk Image from Physical Drive'
- Select the Disk you wish to backup from the list
- Choose a place and name for your CF HDD Image File
- Make a Coffee and browse the Amibay 'for sale' section whilst the progress bar makes it's way from left to right...
- Insert your blank CF card into your PC's USB Card Reader
- Open WinImage
- In the menu bar at the top choose 'Disk/Restore Virtual Hard Disk Image on Physical Drive'
- Choose the Disk you want to restore to *Be very careful not to choose the wrong Disk as you could erase another drive by mistake!* You have been warned
- Browse to your backup folder and choose the image to be restored
- Now it's just a case of waiting for the image to be written to the CF Card.
Thanks for reading!
Enjoy
