SkydivinGirl
Retro Girl
Hello all you Amiga Gurus!
I'm installing a Picasso II Rev 1.4 board in my A4000D. Since I don't have a manual, I've been searching the web for information on the jumper settings and drivers. I'm very happy I had to search because I found out about the need to remove the R307 resistor to avoid voltage going to PIN 9 of the video output.
When I went to remove the resistor, I was greeted with a really nice surprise. The resistor had not been removed, but it was not soldered directly to the board. There was a single pin socket installed on both sides of where the resistor should have been soldered. The pins of the resistor were bent at 90 degree angles and plugged in, just like a chip would be. Has anyone seen this before?
I removed the resistor, attached the pass-thru cable, plugged in the monitor, then turned on the Amiga. The pass-thru is working properly.
Now, I need to know how to proceed. Should I use the P96 software on Aminet? If so, which one do I use? Or, should I use the Unofficial P96 software?
I could not find the manual for the Rev 1.4 board so I don't know what the jumpers do. I know I need to turn off segmented mode. Can anyone point me to a manual or tell me what I need to set the jumpers to?
Finally, is there a guide for installing and/or configuring the P96 software? I think I read that I need to know my monitor's VSync and HSync settings, but I don't know how I set those up.
Thanks for your help everyone!
Heather
Heather
