Exilent
Here's the list for now: - UNTESTED!
All without postage, ask me.
Akai LCXSYP3 MB88525 192G (fujitsu) - CMOS SINGLE-CHIP 4-BIT MICROCOMPUTER WITH MULTI IO PORT - 10 euro
AMD - (D8237A) - 5AM9517A-4PC - Multimode DMA Controller - 2 euro
AMD - P8088-1 - CPU (1978 enhanced version of the 8088 with 10 MHz - 8088 is a reduced and cheaper version of the 8086 - 5 euro
AMD - P8088-2 - CPU (1978 enhanced version of the 8088 with 8 MHz - 8088 is a reduced and cheaper version of the 8086 - 5 euro
AMD 3013149-00 - FPU - (Intel 3013149-00A 8080) - 10 euro
AMD AM9080ACC (D8080A) - cpu - 1977 - 2mhz - 5 euro
AMD AM9517A-5PC (IntelP8237A-5) - High Performance Programmable DMA Controller - 5 euro
AMD D8086-1 - CPU Ceramic (1978 enhanced version of the 8086 with 10 MHz - 8 euro - sold to BlindGerMan
AMD D8086-2 - CPU Ceramic (1982) - enhanced version of the 8086 with 8 MHz - 8 euro - sold to BlindGerMan
AMD D8088 - cpu ceramic - 1982 - 5 mhz - 5 euro - sold to BlindGerMan
AMD P8085A - cpu - 3mhz - 5 euro
AMD P8086-2 - cpu plastic - 8mhz - 1978 - 5 euro - 7 left
AMD P8255A-5 - PERIPHERAL INTERFACE, 40 Pin, Plastic, DIP - 3 euro - 2 left
AMI - REF1116 - 1988 - Chicony - Keyboard bios plus, 27C256, REF.1116, 1 euro
Ami C021698-01 - Atari 1983 - PAL ANTIC-B HC1698 videochip Atari 800 XL - 5 euro - sold to rgrocha
AMI S6800P - CPU - 1mhz - 2 euro
Amstrad 40007-4x - Gate Array for video output CPC 464 - 5 euro - sold to jimbob
Exar 2402ACP - 40 pin dip - MODEM Circuit - V.22 bis,V.22,212A Compat,300 BPS min. - 2 euro
Faraday FE2100 - Floppy Disk Controller - 3 euro
Fujitsu MB8841 - 4bit Microprocessor - dip42 - 3 euro
fujitsu mb88401 4-bit nmos singlechip microcomputer - 3 euro
FUJITSU MBL8041A(H-E-N) NMOS Universal Peripheral Interface 8 - 2 euro
Fujitsu MBL8086-2 (plastic) - CPU - NMOS 16-Bit Microprocessor - 5 euro
Intel 8155 - 2048-bit static HMOS RAM with IO ports and timer in 40-pin DIP package - 3 euro
Intel C8087 - Math Coprocessor - 5mhz - 1978 - 5 euro - sold to BlindGerMan
Intel Corporation - P8291A - s4516 GPIB TALKER-LISTENER - 2 euro
Intel Corporation - P8355 (1977) I-O Port Circuit - 2k Bytes of ROM - 3 euro
Intel D8202A DRAM controller (40-pin ceramic sandwich DIP) - 3 euro
Intel D8203 - 1981 - 64K DRAM Controller - 3 euro
Intel D8741A - 1977 - Universal Peripheral Interface 8-Bit Microcomputer - 2 euro
Intel D8742 - CPU - 1977 - 12mhz - 10 euro
Intel D8749H - HMOS-E Single-Component 8-BIT Microcontroller - 1 euro
Intel D80287-10 - FPU - 10mhz - 15 euro
Intel Intel D8086-2 - CPU Ceramic - enhanced version of the 8086 with 8 MHz - Mycron 2000 computer - 10 euro - sold to BlindGerMan
Intel P8031AH - 1980 - 8 Bit control oriented Microcomputer - 2 euro
Intel P8042AHP - Universal Peripheral Interface 8 Bit Slave Microcontroller - 1 euro
Intel P8049AH - 8-Bit Microcontroller-Microcomputer - Use 8080-85 periph. - 3 euro
Intel P8085A - CPU (1976) - 3mhz - 5 euro
Intel P8237A-5 - High Performance Programmable DMA Controller - 5 euro
INTEL P8242 - (1977) Universal peripheral interface 8-bit slave microcontroller - 3 euro
Intel P8255A-5 - PERIPHERAL INTERFACE, 40 Pin, Plastic, DIP - 3 euro - 3 left
Intel P8272A - IC,Single-Double Floppy Disk Controller,MOS,DIP,40PIN - 2 euro
ITT - SAF1190-196 (BMW 520 panel - Aviation use) - RARE - 5 euro
Mitsubishi - M50734SP - 8-BIT CMOS MICROCOMPUTER - 6502 enhanced version - 5 euro -2 left (used in Star LC10)
Mitsubitsi - M50957-XXXSP - SINGLE CHIP 8 BIT CMOS MICROCOMPUTER - 1 euro
MOS - 6532A - Atari VCS 2600 - CBM 8250LP and SFD 1001 drives - 5 euro - reserved for chipitos
MOS 6561 E - Video Interface Chip PAL - CBM VIC20 - 5 euro - Sold to MCes
MOS 8565R2 VIC II Video Interface Chip - c64 (G+Aldi) - 7 euro
MOS 5710 Custom Floppy Controller and Gate Array - C128DCR - 5 euro
Mostek 8240 MK3886N z80 combo - 5 euro
Mostek MK3870N - MCU - 4mhz - 5 euro
Mostek MK3880N-4 - CPU (z80) - 4mhz - 5 euro
Motorola - MC68A02P - Microprocessor With Clock and Oprtional RAM - 2 euro
Motorola - MC68B44P - DMA Controller - Four DMA Channels - 2MHZ - 7,50 euro
Motorola - MC2674B - ADVANCED VIDEO DISPLAY CONTROLLER ( AVDC ) - 5 euro
Motorola - MC6800P - CPU - 1979 - 1mhz - 5 euro
Motorola - MC6802P - CPU - 1mhz - The 6802 is an enhanced 6800 with 128 bytes of RAM and an internal clock oscillator added - 5 euro
Motorola - MC6809P - CPU - 1mhz - 1986 - Tandy-Radioshack - Dragon32 - 5 euro
Motorola - MC6820P - MPU - PERIPHERAL INTERFACE ADAPTER - 2 euro - sold locally
Motorola - MC6821P - PERIPHERAL INTERFACE ADAPTER - 3,50 euro 4 left
Motorola - MC6845P - CRT controller - 5 euro
Motorola - MC6847 - VIDEO DISPLAY GENERATOR (VDG) - Laser 200-310 - 7,50 euro
Motorola MC68B09P - 1820-2624 (hp part number) - CPU - 2mhz - 7,50 euro
Motorola xc68hc11A1p - CPU - 5 euro
Nec D553c - 4-Bit MC - CPU - Many handheld games - 2,50 euro - 2x left
NEC D8088D - CPU - 5mhz - 5 euro
NEC D8088D-2 - CPU - 8mhz - 5 euro
Nec D8255AC-2 (z80) - CPU - 4mhz - 5 euro - 10 left
Nec D8255AC-5 (z80) - CPU - 5mhz - 5 euro - 5 left
Nec NEC D765AC - CPC - µPD765 - Floppy Disc Controller (used in DDI-1 and CPC 664-6128) - 3 euro - 3 left
Nec NEC D765AC-2 - CPC - µPD765 - Floppy Disc Controller (used in DDI-1 and CPC 664-6128) - 3 euro - 3x sold to roy bates - 0 left
NEC P8255A-5 - PERIPHERAL INTERFACE, 40 Pin, Plastic, DIP - 3 euro
NEC V20 D70108D-10 - CPU - 8088 10mhz - 5 euro - sold to sohanlo
NEC V30 D70116C-10 - CPU - 8088 10 mhz - 5 euro - sold to commodorejohn
Oki C012294-22 - Atari 1979 - Sound chip used in 5200, 8-bit computers, some 7800 carts, and arcades (DLB) - 5 euro
OKI M80C88 - CPU - 5mhz - 5 euro
Paradise Systems - PPC11 38302C (ppc1-1 38302-2) - Gfx card chip - 5 euro
Philips MAB-8048HP - 8-Bit Microcontroller-Microcomputer - P2.0-P2.3 CONTAINS 4 HIGHER ORDER AD.BTS - 5 euro
Rockwell R65C52P3 - Dual Asynchronous Communications Interface Adapter (DACIA) - 1 euro
Sgs thomson - 3265-07590 - NPN General Purpose Amplifier - 2 euro - 2 left
SGS Z8681B1 - Romless Microcomputers - 3 euro
SGS-Thomson - EF6805U3P - 8-bit Microcomputer - 2 euro
Sharp 252535-01 (CBM) - 1989 - C64E Custom Chip-C64GS - 5 euro
Siemens - SAB8086-1-p - CPU - 10mhz - 5 euro
Siemens - SAB8086-2-p - CPU - 8mhz - 5 euro
Siemens SAB 8086-2-C - CPU - 8mhz - 5 euro\
Siemens SAB 8155P - RAM-I-O-Timer (RIOT) - 256x8,tAD 400ns max - 2 euro - 2 left
Signetics - 20417-54 - 8031 - Keytronic Keyboard controller - 1 euro
Signetics - N8X305N rev A - 1976 - RISC Microprocessor - 8-Bit Microprocessor - Mux IO + separate inst,addr - 10 euro
Signetics - SCN8049HCBN40 - 8-Bit Microcontroller-Microcomputer - Expandable Memory & IO,2 Test Inputs - 3 euro
SND5027E - is a monolithic circuit based on Atmels smart power BCD60-III technol- ogy. It is a universal IC for monitoring basic functions of an automotive application - 5 euro
Toshiba - TMP47C870N - CMOS 4-BIT MICROCONTROLLER - audio app - 10 euro
Toshiba TC8578AP - RS232 or Centronics interface - 1 euro
Toshiba TMP8085AP, old Logo - MPU - 3mhz - 5 euro
UMC - UM8398 - Single-chip Floppy Disk Controller - Vidi Amiga Bus Adapter_bestanden - 2 euro
Vtech P80C51 - 80C51 8-bit microcontroller family 4K-128 OTP-ROM-ROMless - Laser - 5 euro
Yamaha YM2149F 'SSG' chip has the same pinout as the AY-3-8910 - Atari ST soundchip - 10 euro
Z8400APS - (zilog SL0071-00) - (Sharp_LH0080A)Z80A cpu - zilog - C128 - Amstrad-Sneider CPC - MSX (sony-sharp-philips) - Bandai Gundam RX-78 - Spectravideo SVI 318 - 5 euro\
Z8420A PS - Z80 PIO Parallel IO Controller - 7 euro
Zilog - IC 4MHZ Z80 NMOS DART 40-DIP - Z0847004PSC COMMUNICATION CONTROLLER - 5 euro
Zilog - Z0853006PSC - Communication Controllers, Serial Communication Controller - 5 euro
Zilog 2892668-00 (SL0029PS) - IC - 2 euro
Zilog Z0765A08PSC - IC,DISK CONTROLLER,MOS,DIP,40PIN - Floppy - IBM - Compatible Format - Amstrad PCW8256 Word Processor - 5 euro
Zilog Z8681-12PS or Z8681-12 - 5 euro
