Selling 10x 19", 1280x1024, 5:4 aspect, Acer B196L monitors.
All have been modified to work with 15 kHz and play nice with standard Amiga video modes.
These are not suitable for the Atari ST/STE. Atari ones are available separately.
Tested on PAL A500, A500+, A600, A2000, A1200.
These are native Amiga video modes compatible, you don't need an Indivision or any other form of scan doubler or anything. Just plug your Amiga in, set up the monitor and that's it.
All these are used, so some wear marks, yellowing, occasional bad pixel or a few are to be expected.
If there's something that stands out, in a good or a bad way, I'll state it separately.
Read this and this if you want to compare against BENQ BL912 and see what to expect performance wise.
In general, they far exceed BL912 capabilities.
More detailed monitor info can be found here.
To set it up properly a series of monitor setup guides is available here.
On AGA machines use the driver supplied on the setup disk to allow for DblPAL mode to be picked up correctly.
No aspect correction in Multiscan AGA video mode as explained here.
Use 720 px width to setup both plain PAL & NTSC.
Prices in the second post. PayPal FF.
EU only.
Nr 1 - 5:
Nr 6-10:
Edit: #6, #9 and #10 sold to Szmn.
Edit: #4 sold outside Amibay
Edit: #3 sold outside Amibay
Edit: #1 sold outside AmiBay.
All monitors from this batch are now sold out.
EU only.
Nr 1 - 5:
Nr 6-10:
