I don't get it. I'm trying to have 4x2GB SFS (v1.279) partitions under WinUAE 1.6.1
This is what I do:
1) Install AmiKit 1.5.0 downloaded from site, using OS3.9 CD as OS source
2a) Do not change AmiKit UAE settings
2b) Change AmiKit UAE settings to include A4k chipset extras and A4k 3.1 ROM
3) Install BB1 and BB2 (BB2 w/ROM Upgrades)
4) Install patches
5) Update AmiKit to latest version with live update to v1.5.9
The 8GB CF card is added as a real HD to WinUAE running with "-disableharddrivesafetycheck" as Administrator.
It's mounted on IDE0 and found by HDToolbox on scsi.device.
I install SFS as SFS/00. It's version 1.279, latest from http://strohmayer.org/sfs/
I use a MaxTransfer of 0x1fe00 and a BlockSize of 521.
I name each partition SD0, SD1, SD2 and SD3.
Each is set to SFS/00 (0x53465300).
Still, when I Quickformat SD0, all is good.
When I format & verify SD3, SD0 is NDOS after a reeboot.
What am I missing here?
In shell version states:
Kickstart 45.57, Workbench 45.3
And version scsi.device states:
scsi.device 43.43
And version c:setpatch
setpatch 44.38
And version "devs:AmigaOS ROM Update"
ROMUpdate 44.57
This is what I do:
4) Install patches
scsi.device 43.43
setpatch 44.38
ROMUpdate 44.57
S:Startup-Sequence said:Code:; $VER: Startup-Sequence_AmiKit+BB1BB2 OS3.9 with both BoingBags and updated ROM file ; Startup-Sequence for AmigaOS 3.9 + BB1 + BB2 + AmiKit (by Jan Zahurancik ©2005-2008) C:Safe RENRAM OWNOUT MOUNTSIZE=6684 ;Checks for viruses C:morelibspace failat 11 C:LoadModule >NIL: L:Ram-Handler L:Shell-Seg DEVS:console.device LIBS:icon.library LIBS:workbench.library LIBS:mathieeesingbas.library REVERSE NOREBOOT ;makes the modules resident (similar to SetPatch) If WARN Set LoadModule 0 failat 1 C:LoadModule LIBS:icon.library LIBS:workbench.library LIBS:mathieeesingbas.library REVERSE NOREBOOT ;makes the rest of the modules resident if previous command fails Else Set LoadModule 1 EndIf If EXISTS C:SquirrelSCSI C:SquirrelSCSI EndIf Set SCSIUpdate 1 If EXISTS C:IDEFix C:IDEFix Set SCSIUpdate 0 EndIf If EXISTS SYS:Expansion/XSurfIDE Set SCSIUpdate 0 EndIf If EXISTS SYS:Prefs/Env-Archive/NOSCSIUPDATE Set SCSIUpdate 0 EndIf If $SCSIUpdate EQ 1 If $LoadModule EQ 1 SetPatch SKIPROMMODULES ram-handler,shell,console.device QUIET Else SetPatch QUIET EndIf Else If $LoadModule EQ 1 SetPatch SKIPROMMODULES ram-handler,shell,console.device,scsi.device QUIET Else SetPatch SKIPROMMODULES scsi.device QUIET EndIf EndIf Unset SCSIUpdate Unset LoadModule C:StackAttack 32768 ;adds stack size to selected value C:PatchControl ;part of MCP C:TagLiFE ;patches the utility.lirary C:Version >NIL: C:AddBuffers >NIL: DF0: 15 FailAt 21 C:MakeDir RAM:T RAM:Clipboards RAM:ENV RAM:ENV/Sys RAM:T/VC_TEMP C:Copy >NIL: ENVARC: RAM:ENV ALL NOREQ Resident >NIL: C:Assign PURE Resident >NIL: C:Execute PURE Assign >NIL: ENV: RAM:ENV Assign >NIL: T: RAM:T Assign >NIL: CLIPS: RAM:Clipboards Assign >NIL: REXX: S: Assign >NIL: PRINTERS: DEVS:Printers Assign >NIL: KEYMAPS: DEVS:Keymaps Assign >NIL: LOCALE: SYS:Locale Assign >NIL: LIBS: SYS:Classes ADD Assign >NIL: HELP: LOCALE:Help DEFER Assign >NIL: L: SYS:Utilities/Expansion/SmartFileSystem/L ADD IF $bbfix EQ "0" ;adjusts AmiKit if both BoingBags for OS3.9 were installed version >NIL: Shell VERSION 45 IF NOT WARN IF EXISTS SYS:WBStartup/AmiDock IF EXISTS SYS:WBStartup/Disabled/AmiDock Delete >NIL: SYS:WBStartup/Disabled/AmiDock FORCE QUIET ENDIF Rename >NIL: SYS:WBStartup/AmiDock TO SYS:WBStartup/Disabled/AmiDock QUIET ENDIF IF EXISTS SYS:WBStartup/ASyncWB IF EXISTS SYS:WBStartup/Disabled/ASyncWB Delete >NIL: SYS:WBStartup/Disabled/ASyncWB FORCE QUIET ENDIF Rename >NIL: SYS:WBStartup/ASyncWB TO SYS:WBStartup/Disabled/ASyncWB QUIET Delete >NIL: SYS:WBStartup/ASyncWB.info ENDIF IF EXISTS SYS:WBStartup/BenchTrash IF EXISTS SYS:WBStartup/Disabled/BenchTrash Delete >NIL: SYS:WBStartup/Disabled/BenchTrash FORCE QUIET ENDIF Rename >NIL: SYS:WBStartup/BenchTrash TO SYS:WBStartup/Disabled/BenchTrash QUIET ENDIF IF EXISTS SYS:WBStartup/DefIcons IF EXISTS SYS:WBStartup/Disabled/DefIcons Delete >NIL: SYS:WBStartup/Disabled/DefIcons FORCE QUIET ENDIF Rename >NIL: SYS:WBStartup/DefIcons TO SYS:WBStartup/Disabled/DefIcons QUIET ENDIF Delete >NIL: SYS:Utilities/Amplifier#? FORCE ALL QUIET Copy >NIL: SYS:Prefs/Presets/AmiKit/Install/System TO SYS: CLONE ALL QUIET SetENV bbfix 1 Copy >NIL: ENV:bbfix TO ENVARC: CLONE QUIET EndIF EndIF C:Version >NIL: SYS:Libs/xadmaster.library 12 1 FILE ;installs latest XAD if BoingBag1 for OS3.9 was installed only IF WARN Copy >NIL: SYS:Prefs/Presets/AmiKit/Install/System TO SYS: CLONE ALL QUIET EndIF C:Version >NIL: SYS:Classes/DataTypes/ilbm.datatype 44 26 FILE ;adjusts AmiKit if BoingBag35-2 was installed IF WARN Copy >NIL: SYS:Prefs/Presets/AmiKit/Install/System/Classes/DataTypes/ilbm.datatype TO SYS:Classes/Datatypes/ CLONE QUIET EndIF ;BindDrivers ;useless on UAE C:Mount >NIL: DEVS:DOSDrivers/~(#?.info) C:LoadMonDrvs ;C:P96-EmulationUpdate ;fakes the version info of emulated CGX libraries under Picasso96 ;C:P96Refresh >NIL: 100 ;set this value (100 by default) according to your monitor refresh rate and WinUAE Display settings SYS:Utilities/Expansion/ShowAmiga96/Bin/ShowAmiga96_Rev239C18 ;shows the picture during startup SetEnv Language "english" SetEnv Workbench $Workbench SetEnv Kickstart $Kickstart UnSet Workbench UnSet Kickstart C:AddDataTypes REFRESH QUIET ;Following two lines provide TrueType support. IMPORTANT: if you disable them you must enable C:WAIT line in front of C:IPREFS to avoid startup crashes!!! Assign >NIL: AfA_OS_Libs: SYS:Utilities/EXPANSION/AfA_OS/AfA_OS_Libs C:AfA_OS_Loader IF NOT EXISTS ENV:afa/replacevisualprefs ;enables the following lines only if similar featrues are disabled in AfA_OS Run >NIL: SYS:Utilities/Expansion/TitleShadow/TitleShadow ;enables effects for window titlebar texts Run >NIL: SYS:Utilities/Expansion/VisualPrefs/VisualPrefs ;enables the customization of Amiga GUI Run >NIL: SYS:Utilities/Expansion/VisualPrefs/TRAP ALL ;enables the customization of Amiga ReAction GUI ENDIF C:Wait 1 ;prevents IPrefs from crashes. Increase the value if IPrefs still crashes. C:IPrefs SYS:Utilities/Expansion/ShowAmiga96/Bin/ShowAmiga96_Login >NIL: SYS:Utilities/Expansion/FullPalette/FPPrefs ;applies FullPalette settings C:ConClip Path >NIL: RAM: C: SYS:Utilities SYS:Rexxc SYS:System S: SYS:Prefs SYS:WBStartup SYS:Tools SYS:Tools/Commodities SYS:Utilities/PicShow SYS:Utilities/EvenMore SYS:Utilities/MysticView SYS:Utilities/SimpleFind3 SYS:Utilities/Expansion/SmartFileSystem IF NOT EXISTS ENV:afa/replacebirdie ;enables gfx patterns for windows borders (only if similar feature is disabled in AfA_OS) C:Wait 1 ;prevents Birdie from not loading the background picture. Run >NIL: SYS:Utilities/Expansion/Birdie/Birdie ? <Env:Birdie.prefs ENDIF SYS:System/REXXMast >NIL: IF EXISTS S:User-Startup Execute S:User-Startup EndIF IF EXISTS S:AmiKit-Startup Execute S:AmiKit-Startup EndIF ;following lines enable enchanced CLI/Shell functionality IF EXISTS DEVS:KingCON-mountlist Assign CON: DISMOUNT Assign RAW: DISMOUNT Mount CON: from DEVS:KingCON-mountlist Mount RAW: from DEVS:KingCON-mountlist ENDIF Resident Execute REMOVE Resident Assign REMOVE C:Version >NIL: C:MakeLink 37 4 FILE IF NOT WARN C:Copy >NIL: ENVARC:SYS/def_RAM.info RAM:Disk.info CLONE QUIET ELSE C:MakeLink >NIL: RAM:Disk.info ENVARC:SYS/def_RAM.info SOFT ENDIF ;Run >NIL: SYS:Utilities/Expansion/PowerIcons/PowerIcons >NIL: ;enables PNG icon support (Don't use it if AfA_OS_Loader is enabled!) ;C:WBCtrl IMT=FAST MNL=100 ;tweaks Workbench Run >NIL: C:CPointer ;centers the mouse pointer on the screen (regardless of the screenmode used). Disable this entry if some of the other CPointer line is enabled. ;Run >NIL: C:CPointer XPOS=400 YPOS=368 MCLICK=50 ;for 800x600 screens, automatically clicks the Dopus "RUN" button ;Run >NIL: C:CPointer XPOS=510 YPOS=455 MCLICK=50 ;for 1024x768 screens, automatically clicks the Dopus "RUN" button ;Run >NIL: C:CPointer XPOS=576 YPOS=500 MCLICK=50 ;for 1152x864 screens, automatically clicks the Dopus "RUN" button ;Run >NIL: C:CPointer XPOS=641 YPOS=579 MCLICK=50 ;for 1280x1024 screens, automatically clicks the Dopus "RUN" button ;Run >NIL: C:CPointer XPOS=797 YPOS=674 MCLICK=50 ;for 1600x1200 screens, automatically clicks the Dopus "RUN" button Run >NIL: C:PatchAsl ;enables MUI file requesters ;C:ChangeExp ;prevents from identifying your system as UAE IF EXISTS S:AmiKit-StartOS ;starts Magellan II, Scalos or Workbench - depends on your MorpheuZ settings. Execute S:AmiKit-StartOS ELSE C:LoadDB EndIF C:MemTrailer SIZE=96 ;provides partial memory protection EndCLI >NIL:
