does it? no the Apple has 4116... wonder what the difference is?
it seems they do work , just the extra capacity isnt used. i need 8
or maybe not , maybe different voltage
---------- Post added at 14:21 ---------- Previous post was at 14:05 ----------
just found this...
I saw some posts recently about replacing 4116 RAM with 4164,
which is more reliable (it uses only one voltage, not three!) and
is cheaper (if you know where to look!). I wanted to come up
with a solution that works for all boards (no board hacking or
harness tricks involved). So here it is:
Take your 4164 chip and bend pin 8 up and over the top of
the chip. Solder a small wire from that pin to pin 9 (which
is directly across from it, and has +5V on it). Pin 1 of the
4164 is not used... just snip it off so you don't have to worry
about the -5V on the board. That's it. The chip is ready
to plug into the socket of the 4116.
You can do almost the same thing with a 41256 (also known
as TMS4256, MCM6256, HM51256, MB81256, etc., 256k*1).
In addition to flipping up pin 8 and connecting it to pin 9,
bend up pin 1 and connect it to pin 16 (that'll tie the high
address line to ground... you can't leave it floating).
I used TMS4256 to replace some blown out 4116 in my
Juno First, and it works great. Runs much cooler!!!
Soldering the wires is a little bit of work, but worth the effort.
