Here is for sale 4X PS/2 USB Mouse adapter for Amigas.
It does not fit in the A600 unless you use an adapter or remove the metal shielding from the dsub connector.
This is not a full USB mouse adapter, this only works with usb mouse which has the PS/2 protocol support.
I am using it with a Microsoft and Logitech optical mouse and it works perfectly, it's also no problem to reach the early startup screen with this adapter.
Here is a list with some USB PS/2 mouse :
https://translate.google.com/translate?sl=de&tl=en&js=y&prev=_t&hl=fr&ie=UTF-8&u=https%3A%2F%2Fwww.amigawiki.org%2Fdoku.php%3Fid%3Dde%3Amodels%3Amouse_liste_ps2&edit-text=
There is certainly a lot more than in the list....
As seen on the first picture, the adapter is protected against shortcut with transparent retractable plastic.
It's based on the aminet PS2M project and re-designed by Mozart @a1k.org.
Asking 11€ each including worldwide shipping (not insured, not tracked at your own risk, possible insured and tracked if you add 3,5€). Paid as paypal gift...
