4xEIDE99
britlord
usa
Michigan
Hi Amiga nuts. I've fixed my 4xEIDE'99 (Track from pin 43 burned in half), so I want to try it again (Sigh). Will a CF card boot right away (connected to the 2.5" Primary port), or do I need to install the driver from the disk first. You see I've had 2 of these and they both never worked (Both burned the same track at pin 43 on the 44 pin header), and I would have never known if I hadn't removed the 44 pin header (Track is under the header)
supaduper
west midlands
if you put you cf on the 44 pin primary port than no you don't need to run the install software.
Why have you removed the 40 pin Primary 3,5" header ?
britlord
usa
Michigan
Because I'll never use it. I'm just want to fit a Cd drive on the other header... Plus it was almost touching the top shield too
supaduper
west midlands
Oh ok, tell us hows goes it dude when you do the set up (y)
