Wanted 50-pin SCSI hard disk
  • Thread starter Thread starter JHanna
  • Replies Replies 3
  • Views Views 421
JHanna
Northern Ireland
I am looking for a 50-pin SCSI hard disk for my Amiga.
Must be at least 20GB (or thereabouts)
Thank you 😊
20 MegaByte or GigaByte?
I don't think there are 20GB 50pin HDD. Only 68/80pin.
On eBay there is currently 73GB external SCSI drive with DB25 connector cable.
So there is a chance it is 50pin drive inside.
Item 296477433487
The last standard using 50pin was Ultra2 (1997). 20 GB HDDs arrived at around 2000/2001. The problem is probably that Ultra160 came out at around 1999 using 68pin and which offered 4x speed compared to Ultra2. So I doubt that there was a serious market in 2000/2001 going for 50pin. And btw, the 68pin already came out in 1989 (SCSI-2 or Wide SCSI) and 68pin been always necessary for 16 Bit (50pin only 8 Bit).
Buy a 68pin and use an adapter, if you have the room for it. Or just go with an SCSI2SD?
I successfully run an 80GB SATA Intel SSD with a SATA2SCSI module (on my A4000T/060), but finding these kinds of adapters today would be a challenge. I use <4GB of it, though.
I've set up a BlueSCSI and a ZuluSCSI with 128GB cards, and built ~32GB partitions on them (for a client using the Amiga for audio and video productions) - I would send you this direction if you just have to have that much disk space attached to the Amiga. I hope you have plenty of RAM if you plan to use FFS on it.
For backup purposes, with the above SD configuration, I feel that being able pull the cards out, and copy the image files off, is called piece of mind. I might also suggest a Network NAS for the home and/or use a wired network card and have less disk space on the Amiga. Aside from the A4000T (for test purposes), this smaller disk and network design is my preferred setup.
