The 68060 is a superscalar (2 issue) and pipelined (4 stages) architecture. Most of the instructions can be executed in one cycle, which are characteristics of a RISC CPU. Actually it is a RISC core with a CISC frontend. The 68060 has a higher integer performance than a pentium, but it's floating point performance is much lower (about 50%), because the FPU of the 68060 is not superscalar. Funfact: Until today the 68060 has the fastest integer multiplaction logic ever built into a CPU. It takes 2 cycles and there is only one CPU out there, that have 2 cycles in an ideal situation, the VIA Nano 3000. Every other CPU takes 3 to 27 cycles.
A 486DX 25 MHz has the same performance like a 68020 25 MHz in the real world (about 8 MIPS). The 486 has a somewhat higher IPC, which starts to show on higher MHz numbers.
