Hi all
Finally my quest to re-obtain a working 1200 is over, so I have got a converter for a CF card, and got a 8 GB CF from Sandisk (Ultra 2, which seems to be the one that works the best).
The 1200 has a accelerator card with a 030/50 and 32Mb of ram (I think is a blizzard; gotta double check), and I've got a CF to IDE adapter to replace the 80MB hard drive that was inside.
Now I'm aware of the OS limitations related to the partition size, and since I am using classicWB, with a 3.0 ROM, I've made 1 OS partition of 600Mb, and 4 Partition for the rest of the free space, keeping every partition under 1.8 Gb (ordered the 3.1 thou, so I can use 3.9 OS, which came with the Amiga that I've got, so it is the licensed CD, but the previous owner never did the ROM conversion so it was never used).
I've read somewhere on internet, that you need to change the default values of the card; because if you don't, you may get issues on file transfer...altho was an old post, so I am not sure if this is still valid
Should I change the TRANSFER value, in HDtoolbox, for each partition? The suggested value is 0001FE00, while I have whatever was set when I did the auto recognition of the drive parameters on HDTB.
Also if I have to change that value, do I loose the data already on the CF? I've already spent time to copy files on it, so I hope that it won't affect anything
Thanks in advance!
Thanks in advance!
