Will sell my A-2000 Tower in parts.
Blizzard 2060 with 68060/50mhz and 128mb ram :
- 68040 @ 40 MHz / 68060 @ 50 MHz
- the 68040s are recycled from used Macs
- memory
- four 72 pin SIMM sockets accept 128 MB RAM
- supports 4, 8, 16, 32 MB SIMMs, 70 ns or faster
- fully autoconfiguring
- maprom selectable by jumper
- Fast SCSI 2 DMA controller
- 7 MB/s asynchronous, 10 MB/s synchronous transfer speed
- 50 pin internal header
- 50 pin external connector
- supported by Linux, NetBSD and OpenBSD
- notes
- 68000 fallback mode selectable with a simple keystroke at startup - works only with rev. B A2000s
- Blizzard 2040 ERC boards with SN# A400001 - A400094 were delivered with a defective DiagROM
- the 68040 processor is recognized as 68LC040 or 68EC040
- boards with these serial numbers had to be sent back to Phase5 to obtain a new DiagROM set including a new SCSI driver
Tested and fully working.
Price : 450.- € + shipping + paypal
Sold to Tom_Rain
Picasso-II+:
- RTG graphics card
- Cirrus Logic GD5428
- 30 MB/s blitter speed
- 85 MHz in 8 bit modes
- 45 MHz in 16 bit
- 28 MHz in 24 bit
- 2 MB 45 ns DRAM in four sockets
- screen modes
- 1600×1280×8 interlace
- 1152×864×16 interlace
- 800×600×24 non-interlace
- optional video encoder module - Pablo
- FBAS and S-VHS outputs
- only PAL compatible
- 15 kHz overload protection
- brightness control
- requires a time base corrector if used with a genlock
- notes
- two 15 pin VGA connectors
- automatic passthrough
- DPMS support
- Picasso96, CyberGraphX 2, 3 & 4, EGS and PicassoRTG drivers
Price : 150.- € + shipping + paypal
Sold
Flifi/Scandoubler A-2320 :
- deinterlacer
- a video deinterlacer board based on the Amber chip from the A3000 motherboard
- doubles all 15.75 kHz screen modes to 31.5 kHz
- HD15 VGA connector
- enable / disable switch
- full overscan support
- dual port static RAM bank - new video and cleaned video are read in and outputted simultaneously
- although originally designed for the A2000 it works in the A4000
- some modifications are needed to fit the board securely into the A4000 video slot
- the board gets confused by some of the doubled AGA modes, and rather passing them through it tries to double them to 55 kHz or above - on these modes the board has to be disabled with the switch
- it samples 12 bits for each colour, on the A4000 the upper 12 bits of the 24 bit AGA information, so AGA screen modes with more than 32 colours or HAM6 will have the colours quantized to a certain degree
- compatible with some genlocks
Price : 120.- € + shipping + paypal
Sold
X-Surf 2:
- Ethernet interface
- Realtek 8019AS chipset
- 10BaseT connector
- 10 Mbit transfer rate
- fullduplex and supports auto-negotiation
- 16 kB databuffer
- autoprefetch
- automatic polarity correction
- Noise Filter Bus Interface ensures proper function in heavy-loaded Zorro systems
- SANA 2 and PPPoE drivers (MNI driver is in development)
- supported by NetBSD
- expansion ports
- 26 pin expansion port compatible with the one on the Buddha/Catweasel controllers
- two clock ports for A1200 expansions
- two IDE ports: 3,5" and 2,5"
- can be activated by the IDE-fix software package
- autobooting is not possible with these ports
- the timing is not configurable
- preemptive use of IDE devices - necessary for CD-writers - is impossible
- all expansion ports are independent from each other and can be used at the same time
Delfina Lite Soundcard:
- DSP
- Motorola DSP56002 @ 40 MHz
- 24 bit data bus - 24 dB dynamic range
- fully programmable using the supplied software
- memory
- 96 kB, 24 bit SRAM, not expandable
- one half of the memory can be addressed in program and X data space, the other half only in Y data space
- zero-waitstate, 12 ns
- audio
- Crystal CS4231A audio codec
- sample frequencies up to 48 kHz at 16 bit
- three stereo inputs (2 RCA, 1 internal CD-ROM), one stereo output (RCA)
- all inputs can be mixed with Delfina's output
- full duplex recording and playback
- AHI driver
- optional serial interface module - DelfSer
- connects to Delfina's expansion connector (DelfExp)
- maximum serial speed is 625000 bps (1/64th of the DSP clock rate)
- lower speeds are generated by dividing the maximum speed by an integer
- DB25 serial connector
- can be ordered with 100% Amiga compatible serial port - including -12V and +12V power - otherwise these signals are simply cut
- allocates a buffer of its own in Delfina's memory, so using DelfSer may disable some memory hungry DSP effects
- a 24 bit S/PDIF digital I/O was also planned for DelfExp, but never released
- notes
- 8 bit Zorro bus interface logic - when running many sound outputting programs at the same time, the system may feel slow responding
Sold to hese
CompZ Bigtower for A-2000:
See pictures !
Little yellowed,some scratches,new fronts available,without extensions/drives !!!
With Motherboard Rev 6.2, Kickrom 3.1, no damage by accu, power supply build in price: 200.- € + shipping + paypal
Sold
Subway USb Card:
- USB interface
- four USB connectors
- compatible with USB 1.1 and 2.0 specifications (but supports only USB 1.1 transfer speeds)
- all ports are protected against overvoltage and short circuit
- integrated power management on port by port base
Tested and fully working, card is from the last production badge by E3B and was only used once for testing !!!
Price : 200.- € + shipping + paypal
I will sell my complete collection of A-2000 material, i have nearly all A-2000 models (only the Unix-Model is missing) and a lot of Zorro-cards,Software,Games,Parts etc.
If you are looking for something special....ask me !!!
CU,
AC
