Hello,
I have to sale a DCE SX32 MK II CD32 Expansion Defective
There WAS battery leackage damadge even that the battery was taked off
Comes with its original package, original documentation in german.
No memory present, NO FPU, NO Quartz Xtal and without IDE 2"1/2 cable.
It's the virgin configuration but you can find a cable an IDE TO Compact flash adaptator to upgrade it.
Maximum memory is 8Mb but i's no reliable
More info there
http://www.bigbookofamigahardware.com/bboah/product.aspx?id=1861
Note that the main difference about the MKI version is a smaller PCB, better electronic design and it allow you to add an 68882 FPU @ 30 MHz Didn't test it
Pictures -> http://s1293.photobucket.com/user/torajaboy/slideshow/DCE SX32 MKII Defective
Asking 200€ for it, it's my last piece! No stock anymore and it's a collector item in Faulty condition.
I performed test and this item is partialy defective and not reliable.
Some time it was seen as working in the Amiga Early set up some time don't but always boot on the IDE internal drive the CIA Chipset but they are ok. Tried to cleaned the Bus board connector without effect. I/O operation serial Floppy and // are OK! Didn't try the RGB signal out put and VGA signal too. Have issue with memory extension not reliable.
I'm sure that the MACH230 have problem but I doesn't have the code to program it. The MAch 230 have to be replace with a working one unit. Maybe this is a false contact problem I doesn't have a electronic pen contact cleaner, just tried with an old and dry ink pen eraser.
Sold as it NO REFOUND
Please don't buy it if you are not feel confidant.
Paypal Payment only fee will be at your charge and shipping cost too.
More info there
