Closed A1200 CAPS replace and timing fix in Japan
  • Thread starter Thread starter ami_junki
  • Replies Replies 2
  • Views Views 1517
ami_junki
Japan
千葉
I have an A1200 rev 1D.1 and it seems that the CAPS need to be replaced and a timing fix done, when using the ACA 1232 I am getting strange horizontal lines on parts of the screen, I am using a 300 watt XT PSU so there should be enough power. If someone is able to do this in Japan I would really appreciate it. Thanks!
hi a 1D1 should not need any timing fixes as its the first board rev .. later boards need timing fixes.
Caps may be the sole problem..
mike :-)
Thanks for the advice Mike, I think I will find someone to do the CAPS here then first and see if that fixes the problem.
