A1200 DF0???
Justin
hello,
Anyone have any idea why an A1200 with a 1D4 board would report DF0 as DF0??? when a disk is inserted? tried swapping drives no change, i don't think it's the floppy controller as the external drive DF1 works just fine
any ideas guys?
cheers, JuvUK
Justin
i believe the ribbon is correctly orientated and is in good serviceable nick, but i shall get it checked:)
ta
---------- Post added at 12:25 ---------- Previous post was at 11:53 ----------
when you insert a disk both drives that have been tried sound right but neither have read the disks, the cable on the wrong way turns the drive light on permanently does it? i seem to remember the DF0??? icon would be on the workbench all the time as well?
StrontiumDog
The Willen Lake
Yes, DF0??? icon would show on the workbench all the time if something was wrong.
Simple things to check: As you look at the rear of the drive, the coloured stripe should be to the far left. Correspondingly, the stripe goes to pin1 on the A1200 (the right most pair of pins as you look at the mainboard).
No nicks or cuts in the cable? Tried different cables to rule out possible faulty ones?
Also a stuck floppy detection switch will make this exact behaviour. Clean it with a small drop of WD40 or other contact cleaner and press it for 10~20 times and test again.
Witcher1979
Westleton, Suffolk, UK
Suffolk
Zetr0
Ya' Like it Retr0?
LOL, just when I get the call!!!!
LTAC
FRANCE
South of PARIS
hello,
any ideas guys?
cheers, JuvUK
Same problem for me with my A1200 (not the ESCOM model)...I think we must to check the PSU (perhaps I confused with different model A500/A600/A1200: some of them are not identical)...check in progress.
Witcher1979
Suffolk
Well mine was easy, I just snipped the wire in the diagram, didnt even need to attach those two pins it was talking about. Both Drives now work perfect :)
Zetr0
Ya' Like it Retr0?
@All
This link might be of some use here
I will have a complete read and see how that relates to this escom mobo.
[edit]
Sweet! thats solved... btw have you tried Non Dos Disks? (NDOS) things like maybe Alien Breed 93 or SuperFrog?
Witcher1979
Suffolk
@All
[edit]
To be honest, have not checked any type of games. The reason I wanted it was to check out all these KTs PD disks and transfer some coverdisks back to ADF (was a pain holding down mouse buttons and making the machine boot from DF1: each time). If you are interested in knowing if NDOS disks work (without that wire) I could copy a few games over and test.
Cheers
Witcher1979
Suffolk
@All
[edit]
After testing it seems only Amigados disks read, I guess thats why I need to whack that wire across for?
