A1200 do not read not dos game
rayan259
Canada
Calgary
My amiga 1200 read all dos game & program but in notdos game after trainer & click left mouse floppy drive Led is on & can not continue
replace another floppy drive - replace rom - replace amiga gotek floppy do not fix but replace motherboard Fix it!!!!
you know what is problem?
THX
roy_bates
resistance is futile!
england
birmingham
what game or games are they? what roms do you mean.
some games require an older kickstart from an older machine.
try a disk called relokick on the machine first then try the disk you want to use and see how you get on.
im guessing this may help you.
BLTCON0
Math inside
Hellas (Greece)
Chania, Crete
THX
Yes, you have a motherboard from Escom which doesn't pass the READY signal through to the floppy header.
The READY signal is not used at all under Amiga OS, but it is used in a lot of NDOS games/demos, hence the problems you have.
The good news is that the READY signal was only disconnected on the internal connector. It was correctly passed through to the external floppy connector.
So, to fix things back to Amiga standards:
1. If there is a wire between pin #2 and pin #34 on the internal connector as seen in this photo, remove it.
2. Solder a wire between pin #34 of the internal and pin #1 on the external floppy connector, as seen in this photo.
rayan259
Canada
Calgary
Thx
Cannonfodder - myth - aladdin..................
motherboard is 1D4 & kickstar by 2 motherboard is 3.0
back of motherboard no wired But i think do step 2 yes?
