Hi there.
Working on my A1200 in blue case this afternoon.
This one is made to be used with AGA and Indi MK3, Freeway USB, Amiblaster CP and a 68060 card.
Currently it is setup with a Blizzard 1260 and MMU libs, IDE SSD with SFS partitions (same base or clone than a SSD working perfectly on another A1200 with Blizzard 1260, and three others with Vampire 1200v2, PiStorm 32lite, Warp1260, so it is a reliable OS3.1 installation). It is working fine, apart from the IDE transfer being significantly slower than the other A1200 with Blizzard 1260 (1,6 MB/s versus 2,5 MB/s, with same partitions, same MaxTransfer, same buffers, same type of SSD and IDE adapter, etc).
However, the computer won't see the harddrive with any other accelerator than Blizzard 1260, including Apollo 1260, TF1260 and now Trinity 1260. I still need to try a Blizzard 1260 PPC but i am afraid this one could blow a tantalum cap in my face as it hasn't seen an electron in 15 years or more.
I can still boot from floppy disks and see that those accelerators are recognized fine with Sysinfo, WhichAmiga and Amigatestkit.
The system is MMULib based.
With anything else than Blizzard 1260, it boots straight to the kickstart screen without delay, with no IDE LED access, and then scsi.device is not found by Sysinfo. No harddrive in early statrup.
Mobo is serviced, recapped with timing fix.
Any idea what could be the issue with this one?
