Found A1200 Motherboard for Blizzard PPC
whistling-ge
Italy
Genova
Hi!
I'm after an A1200 motherboard, I need it to be compatible with my Blizzard PPC 603e and BVision PPC.
Maybe even with Mediator, some day.
That is why I want a revision 1D1, 1D4 or 2B.
Recapped is a plus.
Any suggestions are welcome.
Thanks,
Tom
Mods, please change the header... "A1200 Motherboard for Blizzard PPC" <Done>
All A1200 MB's are compatible with that combination. I've got 1b and it works without problems. If you intend to go for a mediator (which is way better, given the fact that there are way better PPC processor cards) you won't need a BVision anymore because ATI cards are more performant and very cheap.
Good luck!
Good luck!
Thanks for your contribution!
Unfortunately the thing is as follows: I tried the BPPC on two 1B's, but the system just goes black on boot and hangs, even if I keep pressing 2 and reboot. No signs of life.
I tried the card on a friend's 1D4, the system boots straight away and runs like a charm.
All things being equal. 3.1 ROM, ATX modded PSU (10A on 5V), CF card with 3.9 as per chucky's instructions. Clean connectors.
I googled and read that this behaviour may depend on the MB revision, on some capacitors for timing issues, but also on some chips (Paula?).
So, if I find a MB that's proven to work, it'd save me a lot of time... :-)
Hi
I have a rev 1D1 and 1D4 avilable I recap them using panasonic caps or can can install polymer caps if needed (extra). PM me if your interested I'm also in the UK.
Found, thanks @retroheaven87.
Great experience overall.
Positive feedback left.
