Hello,
I recently bought an A1200 locally. It worked fine when I got it, except for an audio problem which I was trying to diagnose and fix. Now I hope I haven't fried something while trying to fix that problem.
The audio problem was that after a while playing sound, the audio would become glitchy (low volume, crackling). I was told that was often a problem with the -12V power, and it just so happened that there was a bodge wire on the board between the negative side of C304 and the positive side of R348, which carries -12V and is related to audio (http://amigapcb.org/index.php shows that line is -AV, and the board schematic shows R348 is part of the audio filter circuit, and C304 is part of the audio decoupling circuit).
So I was in the process of replacing the bodge wire with a new one (with the machine powered on and playing audio, so I could hear the fix worked), which seemed to do the trick, but then I *think* the wire touched a pin on the Budgie chip or something, because the screen became black and sound stopped. Since then, I haven't been able to boot the machine. Even if I remove the new wire.
I have unplugged everything I could to reduce the variables (the machine came with an ACA 1230, an IDE to CF adapter with an 8gb CF card, etc.). The only things I left plugged in are the Indivision AGA Mk2 plugged into a monitor using a DVI to HDMI adaptor (otherwise I wouldn't get any image -- I don't have an RGB monitor or anything that accepts composite video at hand) and the keyboard.
The symptoms as of now are:
* When I turn power on, caps lock blinks on then off. The power LED on the keyboard is on.
* The screen shows only the Indivision splash screen in the top left corner but it's weird, it says 13951Hz. See attached screenshot.
* The rest of the screen is black and stays black no matter how long I wait.
If I plug my IDE to CF adapter back in, the disk usage LED doesn't even light up, which makes me think it doesn't even try to start booting up.
What can I do to diagnose what's going on? Are there any tests I can do to figure out what's wrong? I've got decent soldering experience (modding game consoles and such) and I can test continuity and voltages, and I even have a small oscilloscope I can use to test things, but I'd need guidance because these are literally my first steps with an Amiga.
I really hope it's not fried!
