Epezpalace
Good evening,
Not so frequent poster but I want share my project here. I haven't heard any kind of similar made. I have acquired A1200 pcb but everything around it were missing. I found that aftermarket solutions to build or buy case and keyboard are not in my budget. Donor case for this project is Philips-brand Blu-ray-player.
Nevertheless, here is some photos what is going on:
First fit with "ESD" bubblewrap
Making room for pcb as removing old plastic fittings
Yep, its a tight fit.
Planning back plate with Lyra keyboard module. No hole for PCMCIA just right now.
Now using computer aided and cardboard aided design of back plate.
And here is first version of back plate 3d printed. First I tried with metal sheet but find it hard to making any holes, cutting or bending it. Original back plate thickness is 0,5mm
Keyboard port was too near of side of the cover plate. In second model this is taken account.
Material was PLA and found that I have to use thicker thickness. It became too floppy as like 5,25" floppy discs. Too difficult connecting cables.
Also notice seam in middle of case. This project has very big homemade-stamp.
In current situation I am going to use old laptop HDD with SATA-IDE-adapter. Maybe CF-card is easier to fit it in.
And there is plastic foil covering bottom of pcb. So don't worry of short circuits.
More room for expansion slot. For expansion card I am still waiting for 8MB mem-addon. Enough for WHDLOAD.
And here is model 2 of back plate. Now with 1mm thickness and some reinforcement. Its not perfect but I learn everytime.
Currently, I have to design mounts for pcb to bottom plate.
Other TODOs:
Other TODOs:
- Proper Amiga/Commodore badges to case
- Color leds to front panel
- Maybe, GOTEK interface to front panel. Using that USB-slot and put screen where is transparent spot in the front panel.
- HDD needs proper bracket for inside install
- Cooling fans?
- PCMCIA slot hole?
- Usage for front disc drive tray ( I'm going not to put any cd/dvd-drives for it
